SOURCE: Fresh Food & Freezer Warm
CHECK AND MAKE SURE YOU CAN HEAR YOUR EVAPORATOR FAN RUNNING (INSIDE MOTOR). IF IT IS NOT RUNNING ... AND YOUR COMPRESSOR IS RUNNING. THE MOTOR OR DEFROST TEMENATION SWICTH COULD BE DEFECTIVE. IF NOTHING IS RUNNING ... TRY TO LOCATE THE DEFROST TIMER(USUALLY LOCATED WHERE YOUR COLD CONTROLS ARE) YOU SHOULD SEE A SMALL HOLE WHERE YOU CAN MANUALLY TURN THE TIMER WITH A SCREW DRIVER.IT CAN ONLY TURN IN ONE DIRECTION. IF THE MOTOR IS RUNNING. CHECK TO SEE IF COMPRESSOR IN THE BACK IS RUNNING ... IF IT ISNT AND IS "HOT" (BE CAREFULL) SEE IF THE CONDENSER MOTOR NEAR THE COMPRESSOR IS RUNNING ... IF NOT ... THE COND. MOTOR IS BAD ... THAT MOTOR RUNS IF POWER IS GOING TO THE COMPRESSOR ALWAYS. IF COMPRESSOR IS HOT AND NOT RUNNING AND COND. FAN IS RUNNING .... UN PLUG FRIG AND WAIT TILL COMPRESSOR IS COOL TO THE TOUCH. THESE COMPRESSORS HAVE AN INTERNAL T-STAT THAT PROTECTS THE COMPRESSOR IF IT SHORT CYCLES.IT SOMETIMES GETS SO HOT IT DOES TAKE HOURS TO COOL OFF. THERE IS ALSO A DEFROST-TERMINATION SWITCH THAT CAN GO BAD. CONSULT A LICSESED FACTORY CERTIFIED COMPANY TO GIVE YOU A FIXED-PRICE DIAGNOSTIC TEST.
SOURCE: freezer works but fresh food seems warm
If you have frost on the back wall of the freezer compartment you have a defrost problem. When the freezer coil does not defrost the refrigerator does not get air for cooling.
SOURCE: Refrigerator won't stop running
to be running quite is normal. Did you shut it off for a reason or did you have a problem?
SOURCE: Whirpool Side by Side making loud humming noise from freezer side
I had the exact same issue last night. I would press on the back panel long enough and the noise would go away only to return this morning at 4am. I finally got up took all of the bins and shelves out and found an very large accummulation of ice at the bottom (floor) and walls of the freezer. The ice accummulation was causing the rattling of the tubes in the wall of the freezer (I don't know what you call them), but they were frozen over on one side. I found this out once I took the back wall panel off of the inside of the freezer. I also found the drain hole back there and it was frozen over solid, as well as my ice dispensing unit at the top of the freezer. This whole problem began when I turned on the ice maker 3 days ago. I used my hair dryer and hot water to clear all of the ice from both areas and now it is nice and quiet. Don't know if the acccummulation is due to some defrost switch gone haywire, but at least the rattling is gone and my freezer is back to square 1 for the time being and I saved myself a visit from the appliance guy in the meantime. Took me a total of 1 1/2 hours to do it all.
