Question about Makita 2 Bl1830 18v Battery,dc18ra Charger Lxt Fr Drill
Hi both red and green lights are flashing and it wont charge battery bl1830 lith ion
  • Makita Master
  • 885 Answers
If both lights are flashing it means the battery is defective so it won't charge it. By defective it could mean the battery is just worn out or there may be a short in the battery. If the battery is under warranty you can get it replaced at a Makita Service Center, if not you have to buy a new battery.
Posted on Sep 13, 2010
Testimonial: "thank you verry helpfull"
  • kingzinoz1 Dec 06, 2010
    I was told that by placing the faulty battery in the freezer,this might help get rid of the fault.Is this true?
    New Friend:
  • 4 Answers
Mine is doing the same but if i used my other charger my batteries charge fine
Posted on Nov 19, 2011
  • paul mc
    paul mc Dec 09, 2014
    bingo! thats my situation,also.....and I do not need some flunky to instruct me to go to the service centre.....D'uh! lol
    New Friend:
    Problem Solver:
  • 15 Answers
Instead of throwing away your tools you can connect it with 18v adapter to make it work thats the last option that i will ever choose.
Posted on Aug 23, 2014
  • paul mc
    kind of not an option,when your 30 ft. up,installing on a building,thats why I need cord-LESS
    New Friend:
I have( 4) 3 amp 18 volt lithium ion batteries for makita tools that will not charge. the charger flashes red and green at me, at 100 $ a piece , i might as well throw the battery saw, impact and cordless in the F' in trash can!! oh and its been just over a year since i bought them
Posted on Dec 03, 2010
SOURCE:
Red light flashing will not charge battery have left over night with no result
Sometimes, this is a result of a battery that is too cold (below freezing-warm it up). Sometimes it can be too hot (discharged under heavy stress-let it cool down). Sometimes there may be insufficient voltage, I have had problems in older houses, get closer to the electrical panel to plug in, or you may have to wait until you get home. Red flashing may mean https://www.youtube.com/watch?v=8rZqYmPsZycthe charger or battery is to hot and must cool down before it will charge. The charger will not charge a battery if the lights are flashing. Solid Red light means it is charging and solid green light means it is charged. Plug the charger in first before putting the battery on the charger. If the charger has been dropped or hit the floor the coil inside could have broke loose and damaged the charger requiring it to be replaced. Below is an unconventional way to charge the battery if the charger is no good. BE CAREFUL
how to charge broken makita BL1830 Li ion battery
Mar 12, 2015 | Makita Cc300dz 10.8V Li-Ion Cordless Tile...
Makita bl1830 charges but stays on static red light
Chargers have been known to lie about what they are indicating. Even though you say the batteries were charged only a hanful of times, they may, in fact, have expired
Apr 03, 2013 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
Makita DC18RA Makstar Li ion Charger three lights
Alternate Red and Green flashing means bad battery. Buy a new one, or take it to a Makita Service center for replacement if it's under warranty.
Normally the yellow light indicates hot battery, but it could also mean dirty battery contacts so the heat sensor can't be read, or that the fan is clogged with dust and unable to cool the battery. The manual says let the battery cool and try again. If the yellow still flashes, it's contacts or the fan.
Read the manual online at:
http://www.makita.ca/data/upload/accessorypbim/417_im_english.pdf
Oct 28, 2011 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
Red and green light flashing on 5 of my bl11830 battaries and they will not take a charge
If you put a battery on your charger and both red and green lights flash it is indicating that battery is defective. There may be a short in the battery or they just may be too old and worn out to charge anymore. If the charger is reading the battery as defective it will not charge the battery. The only fix is to buy new batteries.
Jan 20, 2011 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
Red and green light flashes alternatingly with only one of my batterys of my makita 18v li-ion fast charger
unplug charger to let it reset. plug back in and then try again, if it still flashes red/green that would indicate a battery failure. check for warranty replacement.
Aug 26, 2010 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
Makita lithium ion battery wont charge
does it have green blinking light when you plug it to mains w/o battery in it ?
Apr 06, 2010 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
When put on charge the green and red light flash
Yep, not the batteries, mine is doing the same thing but my second charger works fine with the same batteries
Jan 19, 2010 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
I have a li-ion Makita BL1830 18V 3.0Ah battery that can't be charged...when on the charger the bottom two lights flash red..it will charge my other battery, so it doesn't seem to be the charger
Sorry Mate your battery is dead...
The makita lithium batterys dont like getting worked hard quickly.
There is a chip in them that recognice each battery to each specific charger. Try another charger. This has not worked for me. Try anyway
Nov 01, 2009 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
Makita 2 Bl1830 18v Battery,dc18ra Charger Lxt Fr Drill Logo
10,383 people viewed this question
Top Makita Drills Experts
John Trevino
Marvin
Marvin
Spud Howell
Are you a Makita Drill Expert? Answer questions, earn points and help others
