True 23 cu. ft. / 651 liter Commercial Freezer T-23F Logo
Posted on Sep 12, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My True 23F has had extensive work performed since I bought it used. On two separate occasions, it worked well for a month, then shut down. At this posting, the compressor will not come on at all. I've checked all coils, contacts, etc. but no luck. Does anyone have an idea or do I scrap it? Also, can anyone give me any ideas on the correct way to set the defrost timer if I get it working?
Dennis Boxerman
Level 3:
  • True Master 1,306 Answers
  • Posted on Sep 13, 2010
Dennis Boxerman
True Master
Level 3:
Answers
1306
Questions
Helped
646929
Points
2787
Http://www.truemfg.com/pdf/InstallManuals/T-SERIES/t_series_english.pdf
this should take you to their site for a manual on your freezer. I has info on the time clock and how to set it.
First, be sure it has the correct power to the unit. I would then check the temperature control. Be sure it is sending power to the compressor unit. If a contactor is used, is the coil on the contactor getting the correct power? Start there and let me know if we need to go further. Good Luck
True T-23F Single door freezer. My freezer isn't running?
Question edited for clarity and better English.
Low on Refrigerant Gas. You need a refrigeration engineer.
Compressor not working
REPLACING TRUE AIR FREEZER COMPRESSOR
T-23f true freezer compressor makes rattling noise then starts sometimes i believe it is the over temp compressor relay
replace the current relay and overload and start capacitor.
look for any looe or damaged wiring as well.
Regarding replacing the temperature control on the True t-23f freezer, I can't find it.
As soon as you open the freezer door the temp control is at the upper right of the freezer.
I have a True T 23f freezer that I know needs a new defrost timer. My problem is finding the right one. The only numbers I can see on the timer are 8141-00B and 345-00. I can also see it's marked 2hp...
That 8141-00B is a Paragon timer model number. If you get the identical one you can just mark the numbers down and be sure to wire in the new one the same way.
We bought the Commercial Freezer T-23F last month and the unit never works right, we had a service persons came in to fix it two time, both time they fix the defrost timer and it still the same. The...
Is it factory new, never been used? Or are you saying you bought a used one and they replaced it with a "new" used one? I am familiar with True Manufacturing and if it is a new unit you have a one year parts and labor warranty. The dealer you bought it from is the responsible party to fix your problem.
2answers
True Freezer- The 5 amp circuit breaker trips when the light on
I believe that breaker is actually for door frame heaters. Most true freezers have a resettable breaker for the door perimeter heaters only.
2answers
T-23F FEERZER
fan burnt or relay fauly or fuse blown
6helpful
2answers
Convert freezer to refrigerator
Converting a freezer to run like a fridg can be done ,however it is sometimes tricky. you have to replace the thermostat, you will also want to shorten the defrost time setting. and may have to disable the fan delay to let the evaporator fans run all of the time, to prevent short cycling of the compressor.
Top True Freezers Experts
Jay Finke
Jay Finke
ADMIN Andrew
ADMIN Andrew
Are you a True Freezer Expert? Answer questions, earn points and help others
