My magicolor 2400w prints fine until i print a photo then it leaves vertical streaks down the page, how do I correct this and if its dirty how do i clean it.
Pleas check transfer belt, and drum unit, probably these lines are
caused by drum unit and you have to change it. also you can clean laser
glass, what is under the drum unit. if both look fine you can also look at the fusing rollers.
I have a Magicolor 2400w and had the same problem... I hope I'm not to late because I almost put mine in the trash.
How I fixed the problem was I adjusted the solenoid behind the fan on the right side. I made a video and posted is on YouTube. Search YouTube for Magicolor 2400w paper size error. or follow the link.
After you have this problem again. Go to Control panel and look for administrative tools. Click on services and scroll down until you see the print spooler service.. Right click on this and select restart. Let me know if the printer then functions after this.
I've had that problem before too, and found out that there were copies of the printer that had somehow installed themselves on my computer. All I needed to do was to choose to print with "konica minolta copy 1" instead of the one that I *thought* was installed and it worked. I then deleted the original printer and just stuck with the copy.
My magicolor 2430 dl prints fine until i print a photo then it leaves vertical streaks down the page, how do I correct this and if its dirty how do i clean it.
jim
