Toys Logo
Posted on Sep 12, 2010
The engines of my sons geotrax will not respond to the remotes and they all have fresh batteries
Anonymous
Level 1:
New Friend:
  • Contributor 5 Answers
  • Posted on Dec 14, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
5
Questions
0
Helped
32611
Points
44
I had the same problem with two of our three engines. I read somewhere that you can get them running by hitting the side of the engine against a hard surface. I can't believe it... IT WORKED! I guess the motor gets stuck and hitting it will get it going. All three engines are working now.
2helpful
I replace the batteries in the remote control and the train will not go. Is there batteries in the train that might need to be replace, if so, where do I find them?
According to the Instruction Manual it requires 6 AAA batteries, you will need a Phillips screwdriver to access the panel where you must replace it.
The remote controller and the engine need batteries.
Engine
• Locate the battery compartment on the back of the Engine. • Loosen the screws in the battery compartment door with a Phillips screwdriver. Lower the battery compartment door and insert three "AAA" (LR03) alkaline batteries. • Close the battery compartment door and tighten the screws with a Phillips screwdriver. Do not over-tighten. • If this product begins to operate erratically, you may need to reset the electronics. Remove the batteries and replace them in the toy.
7helpful
Geotrax remotes work..trains wont go. I have cleaned contacts..new batteries...and cleaned axles
Aha! I found this on another forum and it worked for me!
I had some luck using a trick I read on the yahoo geotrax group.
Make sure you have good batteries and hold the controller in the forward movement position. Then run the train forward repeatedly on a surface with friction (I used my pant leg). I got two old trains to work again, and I'm hoping to fix one more.
The theory is that this works because it uses a magnetic coupling instead of a direct drive.
It only took me one super gentle swipe across my leg! Better than smacking/bashing them because that can knock wires loose and stuff. Hope this helps everyone! :D
1helpful
The controller for my geotrax train is not working...any tips?
Yes! Thank you! Holding the remote in forward and running the train over and over worked! It took me a few tries, and finally I did it for about 30-40 seconds continuously, and it worked!!!! Thank you!!!
138helpful
29answers
I have a geotrax train that is not responding to its remote. I put brand new batteries in it and it still does not work. The remote makes the noise and the red light lights up on top of the train. Is there...
I had the same problem with two of our three engines. I read somewhere that you can get them running by hitting the side of the engine against a hard surface. I can't believe it... IT WORKED! I guess the motor gets **** and hitting it will get it going. All three engines are working now.
12helpful
My geotrax engine will light up and the remote makes the sound but it wont move foward can it be reset?
MY SON DROPPED MY REMOTE AND IT STOPED WORKING. i BOUGHT BATTERIES BUT IT STILL DOES NOT WORK
Buy a used remote on ebay, put new batteries in it, take it to a dealer and have them test the remote, if it is good have them teach your car to respond to it. it won't cost much and make your son pay for it.
2helpful
Geotrax is not working...new batteries in remote control...batteries go anywhere else?
I assume you have batteries in the engine. If the engine light comes on and the remote makes noise, the engine motor may be stuck. Try hitting the side of the engine against a hard surface, which may get the motor moving. I had this problem with 2 engines and fixed both of them.
Nov 07, 2010 • Toys
40helpful
5answers
GEOTRAX REMOTES ARE NOTE COMMUNICATING WITH TRAIN ENGINES. SET HAS BEEN IN STORAGE FOR A YEAR. WE SET UP AND CHANGED ALL BATTERIES, HOWEVER, REMOTE DOES NOT MAKE THE ENGINES MOVE. REMOTE DOCKING STATION...
My devices suddenly stopped responding to my remote even though the remote looks to be working normally
Remove batteries, let it sit for a minuit then put in some fresh batteries.
Still not working?
Plug it back into your computer and load Harmony Remote software. Click on "update remote" this will reload the firmware and programming.
I've had a couple harmony remotes go wackey on me but normally re-loading the programming or putting in fresh batteries fixes em right up!
Cheers,
Kevin
Samsung BD-P1200 (Bluray) Remote Control stop responding
Try resetting it.
Remove the batteries and hold down the POWER button on it for 30 secs. Then replace the batteries with fresh ones.
Top Fisher Price Toys Experts
ADMIN Andrew
ADMIN Andrew
Jennifer Rock
Jennifer Rock
NOEL
NOEL
Are you a Fisher Price Toy Expert? Answer questions, earn points and help others
