Unable to download photographs to pc. I can download photos from another camera so the problem would appear not to be the pc. have checked the pc for virus but none found.
You neglected to specify the make and model of your camera, so I'm going to assume it uses a memory card of some type.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Consider NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa. Organize edit and share your photos
It's very hard to troubleshoot software problems online, and it likely is a software issue. But why put up with the headache of these software problems? Please see the following post, as it outlines a much easier, faster, and less error prone alternative way to download your photos (it's what most, if not all professional photographers use):
It's very hard to troubleshoot software problems online, and it likely is a software issue. But why put up with the headache of these software problems? Please see the following post, as it outlines a much easier, faster, and less error prone alternative way to download your photos:
Have you tried downloading with a different software? * Picasa is one option (download from www.picasa.com) Otherwise, you could try and import the photos using Window's Digital Camera Import Wizard
If any of these two methods work, then it is PhotoShot that has the issue. Otherwise, it might be the camera.
