Motorola Mobility SLVR L7 Cellular Phone Logo
Posted on Sep 11, 2010
My motorola l7 volume suddenly going very low that i find it difficult to hear the callers voice clearly.now what to do to increase the sound?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Aug 02, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
90
Points
My phone hear so bad and high
How to increase volume ?
On my Motorola when the mode is in Telephone, the two right side buttons increase and decrease the phone volume.
Aug 11, 2014 • Cell Phones
1helpful
I can hear callers but they cannot hear me. Mute is not engaged,
Please see the link below for the User's Guide.
• Headset is muted. Long press (3 sec.) the volume down button on headset to unmute the microphone. See page 16.
• Improper positioning of voice tube. Try various other positions.
• Voice tube may be clogged. Remove voice tube and test to see if callers can hear you without it. If they can, then replace the clogged voice tube. See page 18.
• Speaking volume is too low. Increase the speaking volume by
adjusting the speaking volume minor adjust buttons on the base unit as described on page 16. If the volume is still too low, select another speaking volume major adjust setting as described on page 16.
• Incorrect configuration dial setting for your phone. Try other
phone configuration dial settings on the base unit. Ensure the
selected number is in line with the position indicator. See page 14.
Plantronics CS70 User's Guide
Good luck from Headsets Direct!
16helpful
My new Nokia C1-01 is very low on caller volume. I can hardly hear my callers properly. How do I increase the volume so that I can hear my callers properly.
oh! your problem is voice of volume. my dear user make sure your volume button and increase your volume voice.this type problem is creates when we are listen a song at low volume voice and forget to increase volume.
1helpful
1helpful
How do i do a reset
may be you volume is set to low. during call use vol keys to increase it
1helpful
2answers
When i call someone they can hear me but i cant hear them what should i do
Hi
first ill suggest if your phone is under warnety then kindly go for support from where you buy, it is much better to utilize your warranty claims on first priority. If your warranty is expire then do the following steps
  1. On the side panel of your phone their is volume key button for increasing or decreasing voice check weather it is not too much low by increasing the volume
  2. you can also check your phone speaker by recording your own voice in , just find this icon in your main menu da6b529.jpg Record your own voice and listen if you are getting your voice clear. or play any ring-tone if your listening any sound from the speaker that mean your speaker is okey.
Note : we often get these problem in mobile communication that we can listen voice of a caller or caller cant able to listen our voice it is because of the disturbance in communication signals, or low signals in high traffic areas.
From all of the above attempts you still not getting any voice from your phone speaker then might be your speaker is not working and you have to replace it , contact authorized samsung hardware support and change your phone speaker .
Thanks
Please Rate !
No sound comes through the ear piece on handset.
dear am seeing that there is really problem in ear piece of mobile u must have to let the check mobile to the repairer shop.
Caller ID set up and poor audio quality
Set up the callers in your contacts. You must have the area code for the name to show up. You must dial the area code for the name to show up when dialing out.
The hearing problem could be the person you are talking to, if your volume is all the way up. If you are sure that it is you I would talk to a motorola technician. Let me know how it goes.
Cynthia
1helpful
Can't hear caller's voice
Turn up the volume control.  Don't have the manual in front of me but go into phone settings and look for the volume settings( not the ringer).  Check in your manual, you'll find it.
Cant hear an incoming caller talk
Press the navigation key: right arrow to increase volume, left to decrease volume. Maximum volume is 7.
Top Motorola Mobility Cell Phones Experts
AFIFUL HAQUE MUFTI...
Level 1 Expert
vince
john h
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
