I've noticed the Echos are cold-blooded and a decent warm-up time is required. You indicate the fuel mixture has to be somewhat rich to keep the engine running. This indicates the needle jets need tweaking to acquire the proper mix (if applicable) or else the fuel pump diaghram is not functioning properly and needs replacement according to the symptoms.
Here is a link to the site that has the G&D (gasket and diaghram) kit and RB (rebuild) kit part numbers for you. You will need to know your machine's model. Link to determine your carb: http://www.zamacarb.com/pdfs/APPL_CR2010.pdf
This is the link to determine the part numbers of the kits. Zama has a great site and informative links:
http://www.zamacarb.com/pdfs/QuickKit_CR2010.pdf
Please vote on this solution.
The first thing that should be stated when you get on to this web site and you need help ---- is that there will be a Fee. I have been unemployed for the last 12 months and can not afford the $7.00 you require. That is why I was trying to fix this problem myself, with the use of this web-site .
Sorry but I will not be able to pay for your sevices.
Thank You and Regards
