2006 KJ jeep which engine? key on 5 times? to prime it? or crank for 5 sec. full? check fuel rail for fuel pressure yet? 700s is GENERAL transmission error. 562 is.battery low (cranked too long error, i bet)
i can see you are using the wrong scan tool that does not do transmission codes from jeep. 700 means , see all those other trans codes you are misssing
quote: FROM KJ 2006 This is an informational DTC letting you know that a DTC(s) is stored in the Transmission Control Module best is to own a scan tool that reads all jeep codes. all factory codes too. P1, P2, etc. innova 3160 will do that.
more.... check fuses yet,>? check voltage to fuel pump cranking/ 11vdc min, summer.
This is seems to be weird issue you are facing with the printer. I would like to know what is the application you are trying to print from ? Is it Microsoft word etc ? Try to type something in Notepad and print and check if the black is printed.
If you are able to print from Notepad then probably it there are chances the application you are tying to use is corrupted and might need to uninstall and reinstall
without thinking anything else do onething.
uninstall your printer driver and going to hp website select the option support and driver. put the model number and select the operating system you are using. be careful to select 32 bit / or 64 bit check it in computer properties and then select the right operating system and download and save on the desktop. then restart the computer and run the s/w you have downloaded.
when you run the s/w make sure the printer is not connected to the computer.
it will give you the prompt to connect the printer and then connect the printer to the computer. follow the wizard and things will work great and all your problem will be resolved.
you can alternately use the installation cd to reinstall the printer s/w if you have.
note installation is done after you restart the computer after uninstalling the s/w.
well........ first of all it depends on the Operating System on you computer, then starting from there the advice that i can give you it is to fully uninstall the software and then install the software back using the version that is on hp.com
after that when you have the full sw installed you have to set up the scan button on the printer from the twain scan window but that will be a piece of cake. just make sure ot get the software properly installled.
completely uninstall all software realated to this printer. disconnect your pc from the web. disable your anti virus and firewall then run your fresh install. if you are getting the diver/software from the web save it to your desktop and follow the first dsirections this should solve your problem
turn your ac on and the fans should come on, if they dont tap them with a hammer and if the come on check the connections and if they are good replace the fans motors
I found a solution before asking help from c-pen support.
1. Uninstall C-Pen software
2. Remove C Technologies entries from registry. They appear in HKEY_CURRENT_USER\Software and HKEY_LOCAL_MACHINE\Software 3. Reinstall C-Pen software (remove the pen from USB before reinstalling)
