Kodak EasyShare CD14 Digital Camera Logo
Posted on Sep 11, 2010
When i try to turn on the kodak camera cd14 it turns off automatically after 3 seconds showing error 1511. Please tell me how to fix this problem?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Oct 15, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
120
Points
My camera does the same thing and i dont know how to fix it
Hi my Kodak EasyShare CD14 Digital Camera is not switching on. I replaced the battery, but there is not any effect on camera. It is not showing anything, and not switching on. How can I switch it on?
Question edited for clarity and written English.
Question moved to model category.
You are the only person to report this problem. It has failed electronically. The only thing you can check is that the battery contacts are clean and shiny. If they have had a depleted battery in there for a long time, they may have corrosion. If that checks out okay, you need to take the camera to a Kodak service centre or a good camera shop for repair.
https://www.google.com/search?q=Kodak+EasyShare+CD14+Digital+Camera+is+not+switching+on
How do you get camera out of menu mode
Try Googling your camera make/model. I did this as an example. I was able to download the PDF manual for free.
Hope this helps. Mike
[PDF] KODAK EASYSHARE CD82 Digital Camera resources.kodak.com/support/pdf/en/manuals/urg01070/CD82_xUG_GLB...
KODAK EASYSHARE CD82 Digital Camera Extended user guide www.kodak.com For interactive tutorials: ... Use power-saving features (see Using the Setup tab, page 28).
How can i get the firmware for the kodak easyshare CD14 ?
You could try the actual Kodak site, but if the camera has been immersed in water it is probably ruined, and installing firmware is unlikely to help.
1helpful
2answers
My kodak easy share cd14 is showing "lens problem
This problem happens because oflong time no using/ Dust or Lens guide pin damaged. If the lens guide pindamage then there is no chance for repairing . Only solution is replacing thelens. For the solution you need to follow the steps.1. Turn off the camera and remove the memory card and clean theexternal body of the camera and make sure in place of the lens there is no dustor damaged sign.2. Now turn on the camera without memory card & make sure thebattery are fully charged.3. If the lens not moving then give a little shake or thrust by hand( carefully very slow) and then wait for a moment. If no changes then turn onthe camera and give a little twist an anti clock side and leave for few second.It is risky ( Do it slowly at your own risk)4. If nothing change then reset the camera setting from the menuoption.After following all steps, if thecamera does not start working then you need to visit service center forreplacing the Lens or Repairing. But before repairing ask service center theapprox cost. if they told you to replacing the lens then do not do that.Because a new lens & service charge cost you near about a new camera price.So best is buy a new camera. If you have any more questions ask me I fell happyto answer your question. Thank you.
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html - - - Doit your self lens fix
How do I upload videos from a Kodak EasyShare CD14 camera to my PC?
Check the Kodak web site for software and downloads to your computer. I did this myself and it cost me nothing. Do you have a mnanual for the camer? if not get one from Kodak.
How can i use my Kodak easyshare CD14 as a Webcam?
Sorry, you can't. The CD14 is designed to store images and videos to memory, not to stream live video to another device.
Does kodak easy share cd14 have expandable memory capacity?
no ! it is set in the ROM
The only expandable item is the memory card that holds your photos
Please rate my help++++Thanks for using FIXYA
EasyShare CD14 Digital Camera: i bought kodak cd14 two days ago but when i insert...
Hi sir =)
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • Not finding what you are looking for?
    Top Kodak Cameras Experts
    ZJ Limited
    ZJ Limited
    Grand Canyon Tech
    Grand Canyon Tech
    Are you a Kodak Camera Expert? Answer questions, earn points and help others
