2001 Dodge Dakota Logo
Posted on Sep 10, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The power window switches for the passenger door and both rear doors stopped working. All 3 switches were replaced, but they only work sporadically. Now I'm told that the master switch on the driver's door is causing the problem, even though it continues to control the other 3 windows, and needs to be replaced. I questioned the replacement of the original 3 swithces and was told that they should be replaced whenever the master switch is replaced. Is this true?
Anonymous
Level 2:
New Friend:
  • Expert 40 Answers
  • Posted on Sep 10, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
40
Questions
0
Helped
10967
Points
115
Check your window lock out swich on the drivers door if locked out or broken it will not lut passenger windowes ip or down
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jun 20, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
688
Points
I had the same problem also. I pulled the driver's side panel off an noticed that one of the switches had become disconnected. This switch seemed to control the passenger window and both back seat windows. This switch also controlled the power side mirrors. Reconnected and now it works fine.
Anonymous
Level 1:
New Friend:
  • Posted on Jun 24, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
688
Points
I have had the same issue, if you pop out the drivers door switches it seem that one of the wires feed the other switches. If you play with the wires while somebody works the other window switches the will run. Iam searching for the wiring diag to see whick wire is the problem wire. Try it
1helpful
2answers
1997 Buick Park Ave, passenger side and rear windows stopped working.
You say the driver window works? wouldn't be a main fuse or fusible link then -driver door locks and window wouldn't work either. Each door has a module inside (computer) . The driver door has a circuit breaker power feed an a fuse DDM fuse 10amp located in rear junction block circuit breaker is located in under hood maxi fuse block. The circuit breaker also feeds battery voltage to the other door modules too. PDM - passenger door module fuse 10amp located in the instrument panel fuse box and the RDM - rear door module RDM fuse 10amp located in the rear fuse box - under the back seat.
Each power window is connected to a permanent magnet motor. The motor raises or lowers the glass when the door module applies voltage to the motor. The direction the motor turns depends on the polarity of the supply voltage provided by the associated door module. The 2 front doors have their own separate modules. The rear seat contains a single module, which controls both of the rear power windows.
A serial digital communications link, called the simple bus interface, is used for communications between door modules and the driver's door power window switches. The use of serial digital communications allows the use of a single wire to convey switching information between the power door lock switch and the driver's door module (DDM). The serial communication is also used in order to transmit switching information from the DDM to the other 2 door modules.
The door modules apply battery voltage of the correct polarity to the respective window motor when any local, or power door lock switch, UP switch is operated, driving the window up. Battery voltage is applied to the respective window motor in the opposite polarity when any local, or power window switch, DOWN switch is operated, driving the window down.
Driver Door Module (DDM)
The driver's door module (DDM) directly controls the driver's door window motor and the express down window feature. The DDM sends window UP/DOWN messages received from the power door lock switch to the passenger door module (PDM) and to the rear door module (RDM) over the simple bus interface (SBI) line. The DDM also contains a class 2 data link which communicates with the other vehicle system modules. The left front power door locks and the outside power mirror are also controlled through the DDM.
Passenger Door Module (PDM)
The passenger door module (PDM) controls the passenger's door window motor. The PDM controls the passenger's door window directly from the right front power window switch or from instructions over the simple bus interface (SBI). The right front power door locks and the outside power mirror are also controlled through this module.
Rear Door Module (RDM)
The rear door module (RDM) controls both of the rear door window motors. The RDM controls the rear windows directly from the rear door window switches or from instructions over the simple bus interface (SBI).
2answers
My front passenger window stopped working. We've checked the fuse, replaced the switch and the door lock button works but not the window. Could this be the motor?
After I verify both driver window control switch and the passenger wdo control switches don't cause the window to operate, I turn off engine and go on ACC Mode and listen for a relay clicking in the door or the BCM while you operate the switch. If you hear a click, then it's a bad wdo motor.
2helpful
3answers
Hi, I'm trying to diagnose a non-working front passenger side power window switch on a 2008 Escalade. Only the lock/unlock function works. The window, mirror and mirror turn signal don't.
Yes they run a wire loom that has wires that are not used in some models. One thing you need to check is the wire loom because it flexes every time the door opens and closes and wires can break .Also you may want to go to autozone website and make a free account, you can put in the year make and model and look for the free repair guides for wire diagrams.
2001 power window ford escape
Rather then swaping parts that don't fix it , testing the electrical is the proper way to diagnose . Using a wiring diagram to locate testing point's in the circuit . Tesing for B+ voltage at the switch , in an out , at the motor etc.... How to test power window switch motor 1985 2001 Toyota
How To Diagnose your Power Window Problem Is the Switch or motor bad
The Trainer 24 Power Window Troubleshooting
3answers
2answers
2005 Honda Accord, all three passenger power windows stopped working. The drivers window works and the window lock is not on. When I try the switch on each of the passenger windows i cvan hear a clicking...
you most likely have a power/ground/switch issue in the drivers door. the power for the other three doors must first travel through the switches in the driver door before it goes to the passengers. hence the reason why when somebody rolls down a passenger window and you push the up button on the driver door the window stops moving. the wires can break inside the rubber boot in the door jam. you can also have an internal problem with the driver door switch unit. you would need a wiring diagram to diagnose this concern.
2helpful
6answers
Windows won't roll down
Does the rear window work from the passenger switch?
Top Dodge Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Dodge Expert? Answer questions, earn points and help others
