Depending on which version of windows you have the directions may be slightly different but in the display settings check to see if it is set to extend the display or to duplicate the display both do very different things. Hopefully adjusting this will correct your issue.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/larry_1fe25e09c54eece2
SOURCE: monitor stuck in "power saving mode"
just press the fn + F5 buttons and screen will appear
Testimonial: "solved, thanks"
SOURCE: I have the VL193 monitor attached to my laptop via
connect external monitor and look it works properly or not .if problem persists , then format and reinstall the' operating system' . use licenced OS(operating system) to install . before that verify that all drivers are present or not . if not , then take the back up of the drivers .
SOURCE: just bought HDMI to DVI
Hi
Desktop PCs automatically seek an external monitor to output graphics to. Laptops default settings send the image to the internal monitor. You need to manually instruct the laptop to export the image to an external monitor.
With the cable connected and the monitor powered up, try pressing the Fn key (bottom left of keyboard) on the laptop and simultaneously pressing the function key at the top ofthe keyboard with an image of 2 monitors (often F5 or F6) to sent d the image to the external screen.
I hope this helps.
