Have you Check the Lamp Fan is it still running while Lamp trys to light?Ballast board is what powers Lamp on ,but if the Lamp Fan is defective Lamp will not light.
BOTH FANS RUN DURING POWER UP SO DOES THAT MEAN BALLAST BOARD IS BAD
Yes its a good chance that the Ballast board needs to be replaced,you said both Fans are running are they the Lamp Fan and Ballast Fan ? what about the DMD Fan located right behind it?
Ive got a 56" Samsung dlp hls5688w tv and im having the same problem. My lamp led light comes on blinking then 2 outside lights start blinking. my manual says that its the fans not operating correctly. could it be just the lamp fan? because the lamp doesnt come on..thanks if any advice can be given
I had this happen tool. I had a color wheel break into pieces. When I replaced it it wouldn't power on anymore. I tried a replacement bulb too, but it kept doing the same thing. Both fans appear to be running. I can feel a breeze coming into the bulb cage.
