If you reach into the hole behind the basket in the pump. You should be able to use a screwdriver to feel around to see if something is clogging the impeller. If so you can work it loose by working it in a counter clockwise direction, than use long nose pliers to pull it out. If that is your problem
Also check all your hoses for leaks.
