Re: cannot install PrintMaster Platinum 2011 When I
Today I tried installing the same software with the registration key #. It kept saying the number was not valid as well. I typed in "O"s instead of zeros. When I typed in the zeros the software allowed you to go through with the installation process.
Administrator privileges are required to properly install the program on Windows® XP, Windows Vista®, Windows® 7 and Mac OS X for PrintMaster Platinum 2011 .
Using mouse, right click on the "setup" and Run as "Administrator"
Troubleshoot Compatibility
This can help with some (but not all) programs/drivers:
1) Uninstall the program if it's already installed. Then when you install/reinstall it instead of double clicking on the install file right click it and select "Troubleshoot Compatibility"
2) Then click "Try Recommended Settings" and in the next window click "Start the Program" to install it.
3) After it installs see if it works correctly. Please note - some programs may not be able to run in Windows 7.
More details about how to make older programs run in this version of Windows: http://windows.microsoft.com/en-us/windows7/Make-older-programs-run-in-this-version-of-Windows
PrintMaster 2011 Platinum encountered the following error:
java.lang.NumberFormatException: For input string: "12,00" at sun.misc.FloatingDecimal.readJavaFormatString(FloatingDecimal.java:1224) at java.lang.Float.valueOf(Float.java:388) at com.storyrock.dlog.PrintWizardDialog.a(SourceFile:1982) at com.storyrock.dlog.PrintWizardDialog.(SourceFile:386) at com.storyrock.ui.actions.PrintAction.doAction(SourceFile:103) at com.storyrock.ui.actions.ApplicationAction$1.run(SourceFile:60) at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:209) at java.awt.EventQueue.dispatchEvent(EventQueue.java:597) at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:269) at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:184) at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:174) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:169) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:161) at java.awt.EventDispatchThread.run(EventDispatchThread.java:122)
If this situation persists, please visit the technical support website at http://www.printmasterpacks.com/support
I installed PrintMaster Platinum 2011 and it first said that I didn't have the correct version of Java for my Mac. I downloaded the required version and was able to proceed with the installation. Did the error happen to say what version of Java is required? If so, going to the Java website and getting the newest update for Windows XP would probably allow you to go ahead and install PrintMaster.
I just installed my PrintMaster Platinum 2011 today on my Mac. Your registration key # is printed directly on the DVD. If there are any zeros in the number and you think they're "O"s, it will say it's an invalid number. I had typed in "O"s and it said that. When I typed zeros it went through to the installation process. Hope this helps!
You're right. PrintMaster Platinum 16 isn't compatabile with Win7. You can either upgrade to which is Win7 compatible or use the program on a computer with XP. You can do this with either a virtual computer or a dual-boot system. If you have Win7 Pro or Ultimate, you can download two programs from Microsoft to create the XP Mode. This gives a virtual computer with XP without needing to buy XP. If you use a virtual computer, just install the software in that computer.
