If you are not getting any suction to the vacuum, but the pump is working fine the rest of the time, start by checking all of your connections that conncets the cleaner to the filter and pump. Make sure there are no cracks, lose hoses, etc. Then, check for the following common problems with your pump that might cause low pressure in pool pumps: 1) Pump not primed 2) Leakage of air into suction system 3) Impeller clogged 4) Valve in suction or discharge line partly closed; Suction or discharge line partly plugged or too small. 5) Plugged basket in skimmer or hair in lint strainer 6) Dirty filter.
