SOURCE: Brother printer HL 5250 DN.
Brother Drum Reset Instructions
The Drum LED continues to blink if the drum counter was not reset when you replaced the drum. To reset the drum follow the instructions below:
Press the cover release button and then open the front cover of the printer.
Press and hold down Go button until all 4 LEDs are lit. Once all 4 LEDs are lit, release the Go button.
Close the front cover.
Make sure that the Drum LED is now off.
Reset the drum counter only when you replaced the drum unit with a new one.
SOURCE: HL-2040 CHANGE TONER
Changing with brand new brother never used drum and toner and reseting drum counter should fix
light expalin link
SOURCE: I've recently installed a new Brother toner, but
DRUM UNIT "spent"
It can be reset if the printing quality is good
Caution: Reset the drum counter only when you replaced the drum unit with a new one.
Testimonial: "A first rate resolving of the drum problem on my Brother HL 5140. Thanks very much, Fixya."
SOURCE: brother hl 5140 drum light comes on then off every 4
With the front cover open,
press and hold down Go button until all 4 LEDs are lit. Once all 4 LEDs
are lit, release the go button, then close the front cover.
This will reset the drum counter.
SOURCE: I've installed a new drum AND a new toner
Try this....
1: Turn off power and remove toner/drum
2: Tape the little spring loaded lever just inside the printer on the upper left hand side in the *DOWN* position! Do not replace drum yet and...
3: Turn power on to printer and let it cycle. Status/Toner lights will come on as usual.
4: Turn off printer, remove tape from lever, replace drum and turn back on.
