You have two windings if it is two speed. What you need is a switch
before your wires come into the motor you need to take one of the leads and run it through a high low switch. This will simply take one of your 110v lines and make it go to high and low speed on the motor.
Green will go to ground, one 110v line will go to common and the other goes to the switch. It comes out as two leads. One will hook up to the low speed terminal and the other will hook to the high speed terminal in the back of the motor.
