Computers & Internet Logo
Posted on Sep 09, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Plugged in memory stick,coputer said ready for use,what do i do next to start process and put my pictures on it,as there were no on screen instructions as what to do to get started,[email protected]
Anonymous
Level 3:
  • Master 32,281 Answers
  • Posted on Sep 09, 2010
Anonymous
Master
Level 3:
Answers
32281
Questions
Helped
7911653
Points
102259
The computer see the Lexar as a external storage device.
Just click on My Computer and you will see the Lexar as a E drive or some other drive letter. Double click on this to open the drive. You can create folders on this drive and copy and paste files to this drive or to the folders just like copying and deleting files on the C drive.
2answers
How to delete pictures on my memory stick pro duo
If you computer has a slot for it, plug it in and use windows to erase what you want. Otherwise try using a camera or another device that accepts sony memory cards.
tip
Sony Memory Stick Formatter Software If your Sony Memory Stick has stopped...
If your Sony Memory Stick has stopped working in your digital device,
Sony's Memory Stick Formatter Software may be able to format your Memory Stick in a more compatible way for your device.
Compatible operating systems include:
* Windows® 7 Starter / Home Basic / Home Premium / Professional / Enterprise / Ultimate
* Windows Vista® Home Basic / Home Premium / Business / Ultimate
* Windows® XP Home Edition / Professional
* Windows® 2000 Professional
Preparation
* Confirm that the write-protection switch of the Memory Stick is set to the "Write enable" position.
* Insert the Memory Stick into the Memory Stick slot of the device or computer.
* If you are using a file recorded on Memory Stick with another application, quit the application before beginning the formatting process.
The Format Process
Note: Formatting will erase all files in the Memory Stick. Always double-check the Memory Stick contents before formatting to prevent loss of important data.
* To start Memory Stick Formatter, click Start->Programs->Memory Stick Utility->Memory Stick Formatter.
* At the "Drive List" screen, click to highlight the drive letter that represents the Memory Stick device/slot.
* Click the Start Format button.
* At the "Warning..." screen, confirm that you wish to format the Memory Stick, and click OK. Note: To quit the process, click the Cancel button.
* Do not remove the Memory Stick from the Memory Stick slot during formatting, as this may cause corruption.
* At the "Format was successful" message, click OK.
* To quit the Memory Stick formatter utility, click the Exit button.
Download the Sony Memory Stick Formatter Here.
I hope that helps.
____________________________________
Click here for Sony's Memory Card File Rescue software.
tip
Preparation
The Format Process
I hope that helps.
Laptop power will turn on, but screen remains completely black
Sounds like a memory problem. Try turning your computer over and finding the access panel that has memory. It usually a small rectangle and may have an icon of memory. Remove the screw (usually only one on Dell's).
You should do this at your kitchen table to avoid static electricity. You will likely have 2 memory sticks in your computer (one may be on top of the other). Spread the clips that holds the memory and remove the memory. Try to keep your fingers off the metal. Remove both sticks (if there are two). Now put them back.
Plug-in your computer. Turn the computer back over, and try to start the computer. If you get the same result, you have some bad memory. The next question is which of the two sticks.
Unplug your computer and remove one of the sticks and try starting again. If it starts, you know that the memory removed was bad. If it does not start, try the other stick of memory and try starting.
If you find the bad stick of memory, all you need to do is get new memory. You can go to one of the memory websites and it will test your machine and determine what memory you need.
Hope that helps.
1GB Memory Stick PRO Duo Memory Card: My sister's boyfriend put my stick into his comput...
Preformat : By Fix-shad0w
#1
Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
#2
Open up 'My Computer'. You should see it under the list of available drives.
#3
Check its contents first to make sure that you have the right drive.
#4
In 'My Computer', right-click on the drive and choose 'Format'.
#5
Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
#6
Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
With A USB , CELLPHONE , Camera The SameThing
tip
Preparation
The Format Process
I hope that helps.
The picture can't copy or move
try to put your memory stick in a different device that can read memory stick like psp, card reader, sony camera etc, then plug it into your coputer then try to copy the image.
How do i transfer digital photos from a picture cd to a memory stick?
Hello.If your using windows xp just put the cd in the drive and plug the memory stick in. Click My Computer and look at removeable devices.Right click the CD drive and then Open.You should see the pictures or information about them.Go to Edit at the top right corner of the screen click it and then click "select all". Click Edit again and click "copy to folder".In the next box look for your memory stick it will be Removeable Drive E: or F: or some other letter near that.Click it to highlite it and click copy at the bottom of the box. When you remove your memory always click safely remove hardware icon by the clock on your desktop. Other versions of windows are similar in process.
builderdale
Using USB Plug, Transferred Photos to Computer and Deleted Them.. Says the pictures are still taking up room on memory card..
Try putting the card in the camera and in the menu, select 'FORMAT' this will totally wipe the memory card, ready for use. You will find plenty replacement cables on Ebay, for about £7.00-8.00
3helpful
7answers
Format Error in Sony Cybershot
i think this problem arises when you fail to regularly format the card ie. take lots of pictures and delete some and repeat the process over and over instead of downloading every session and formatting the card causing coruption. Also if you've bought pro duo memory stick off ebay poss. its a very good forgery (again i've been caught out by this).
Top Lexar Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Lexar Computer and Internet Expert? Answer questions, earn points and help others
