Razor Pocket Mod Betty Logo
Posted on Sep 09, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My bike charge up but when i unplug it it only rides slow what wrong with it it wont speed up
Guy Sutton
Level 2:
Scholar:
  • Expert 192 Answers
  • Posted on Sep 09, 2010
Guy Sutton
Expert
Level 2:
Scholar:
Answers
192
Questions
Helped
42446
Points
391
Check the oil, that will slow it down very very fast..... Guy
1helpful
I have a 1999 Yamaha Roadstar 1600. I ride the bike for minutes or hours and the bike stops running. The bike has no electrical power and wont start leaving me stranded. If i wait a few hours the bike...
Check if the charging system works ok.
At idle with lights off, you should see 13.5-14.5V on battery's terminals and 0.5V less with high beams on, at idle speed as well as at 4000rpm.
Use a fresh good verified battery to take the readings.
I have a 2000 suzuki intruder 1500 lc, battery just went dead and turns over very slow and then dies, I just bought a new battery today and the went dead after riding for a few minutes, once again it turns...
Sounds like you have a bad stator or rectifier. If you like to work on your own bike get a repair manual it will give you several test you can do. Charge the battery to full charge, take a volt meter and put in on the battery leads pos to plus and neg to ground. start the bike and watch the meter it should be putting out over 13 volts if it is not have your rectifier and stator checked by a pro. also check the compression valve cable it may be out of adjustment . I had one of those bike for 13 years a great bike
Basically I'm losing a lot of corner speed, when turning into corners. I shut the throttle off too early and it feels like I'm carrying the bike round the corner. If adjust the throttle mid bend,...
You need to accelerate very gently while you go round the corner. This sounds wrong but even if you hold the throttle in the same position, physics dictates that as you go round the corner you do actually accelerate as you go round a corner at a constant speed (velocity/direction/speed - look it up if your interested!).
So on the approach to any corner, you need to: -
1 Position yourself and the bike for the approaching bend, toward the right hand side of your lane for left hand bends and vice versa.
2 Adjust your speed to one you can quite happily ride around your bend (Slow down by easing off the throttle or appling the brakes)
3 Once at the right speed, (off the brakes) select the right gear for the speed your doing.
4 GENTLY apply some throttle to stop the bike slowing down anymore.
5 Tip the bike into the corner by gently pushing on the left bar for left handers or vice versa keeping the throttle still so that you hold your speed through the corner.
6 As the bend opens up (becomes a straight) gently apply more throttle as you release the pressure on the bar and stop turning.
If you want to keep improving your riding skills, sign up to a advanced riding course. They are for people who enjoy riding and want to be safer and consequently faster.
Good luck with your riding and enjoy!
2answers
Wont start batteerry checked ok , if i jump it with cables it starts , but will not start again the next day
the battery may seem ok, but it's obviously discharging itself or not charging during riding.
Try this...charge the battery with a battery charger.
disconnect the charger, and put a volt meter on the battery.
Start the bike.
Rev up to 2000 RPM. If the voltage is not HIGHER than it was before starting the bike, there's something wrong with the charging circuit.
If it IS charging, turn the bike off, and disconnect the battery overnight.
If the bike will not start the next day after reconnecting the battery, the battery needs to be replaced.
If the battery is NOT charging at 2000 RPM, the charging circuit is bad, and is likely what is draining the battery overnight.
Hyosung avitar 650 wont stay running
Maybe this will help. This is a common problem that I have had with my GV250. Almost the same bike mechanically by Hyosung.
If the battery is low on charge and you are lucky enough for the bike to start. As per normal when first started it revs higher because the bike is cold, this turns the alternator fast to give you the electricity you need to keep the bikes computer working properly. Bike will warm up and revs drop down, alternater not turning as fast, not as much electricity being made. Bike will either stall or rev up and down irradically to try to produce its own electricity. This will occur when the battery charge is low and bike is at low revs, for example when you slow down for traffic or you stop.
If this is your problem. To resolve it when you are out on the road, keep the revs up, twisting your throttle gently when you are going slow or stopped. Give the bike a good long run on the open road to give the battery some charge from the alternator.
Make sure your battery is maintained. If you dont use your bike for a while it will lose charge just sitting there doing nothing. Give the battery a good deep cycle charge or take the bike for a good long open road ride.
03 Suzuki GSXR 750 keeps shutting off while I am riding?? HELP!
Seems you are running entirely off your battery.
Indications are a suspect lighting or source coil is shorting. Resistance test will show discrepancies. Data is available on-line, search technical/electrical manuals from Clymer or Haynes. An auto shop sells cheap multi-meters than you can use. It is a stationary test and will identify individual component problems. As rectifier/regulator, cdi box and wiring/switches/connections all have an effect. These test are outlined within these publications. Cheers (and don't get caught)
1helpful
2answers
CHARGE BATTERY, THEN START BIKE UP. AFTER RIDING
Sounds like you are not getting a charge from the alternator. You need to check battery voltage with a meter with the engine off, key off. Then again with it running, and the voltage should increase. If not, it's not charging.
2answers
Bike shuts off???
if when your bike gets to riding temp. and, you turn it off; and, then restart... if the crank speed is slow replace your battery if your crank speed is normal replace your ignition module (batteries can be recharged and, measure 12 volts and, still be weak)
Amps can fall off (amps are what give the battery muscle to spin your starter ) ignition modules can be affected by heat and fail to maintain spark
1helpful
How to operate a used power wheels ninja?
It sounds like your power wheels battery is low. Have you charged it up for more than 18 hours.
I seems like power is getting to the back of the toy, so I think it might be the battery.
I would also ask the people at this website http://www.shopjandl.com/kids---baby-ride-on-toys-power-wheels.html
1helpful
Want to increase idle speed for ride day.
congrats for your new bike
since its a new bike all you have to do is go to the manufaturer and the will shoot your trouble
Top Razor Health & Beauty Experts
jws1013
Are you a Razor Health and Beauty Expert? Answer questions, earn points and help others
