Question about Frigidaire Affinity ATF7000ES Front Load Washer
Loc - Frigidaire Affinity ATF7000ES Front Load Washer
    President:
  • 1,554 Answers
It means the control is locked to avoid having someone accidentally start or stop the dryer. Press and hold the Options and Select buttons for 10 seconds or until the “LOC” on the display is cleared. Locking the control is done the same way it is unlocked.
Posted on Sep 09, 2010
SOURCE:
What does a LOC code mean?
loc has to do with control lock:
control lock (press and hold)
to lock the controls between or during cycles, press and hold the add steam button for 5 seconds. loc will be displayed if you attempt to wake up a "between cycle" locked unite and loc will alternate with cycle time remaining in a "during cycle" locked unit. repeat to unlock the controls when you are ready to operate the washer. use this feature to reduce the likelihood of accidental operation by children.
Sep 03, 2015 | Kenmore Dryers
How do I reset lock on my Sure-Loc safe box?
Contact Sure-Loc customer Service:
customerservice@surelochardware.com
Address 2855 S 1030 W
Salt Lake City, Utah 84119
Phone 801-261-9362 Phone
866-674-7873 Toll Free
801-261-9364 Fax
May 15, 2014 | Sure-Loc Electronic Keypad Deadbolt Lock...
Whirlpool loc
From a google search the following is copied:
LOC is a control panel lock not a door lock, see below.
The Control Lock shuts down the control panel pads to prevent
unintended use of the ovens.
When the control is locked, only the CLOCK, TIMER SET and
TIMER OFF pads will function.
The Control Lock is preset unlocked, but can be locked.
To Lock/Unlock Control: Before locking, make sure the ovens,
Timer and Timed Cooking are off. Press and hold START/ENTER
until a single tone sounds and "Loc," a picture of a lock and
"START?" will appear on the oven display, about 5 seconds.
Repeat to unlock and remove "Loc" from display.
If the above does not work have you tried removing power from the uit for a few minutes to see if it will reset.
________________
http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/499415-whirlpool-double-oven-shows-loc-display.html
Jan 26, 2018 | Ovens
2004 kawasaki 110cc took apart back tire area and have a thick metal cylinder shaped object and forgot where it goes
hi there hicks32
that metal object is a rim loc , it should have a rubber top bonded on it , this fits into another hole other than the one that the tube valve stem goes into
you should have 2 holes ,fit rim tape, fit one side of the tyre bead, instal rim lock ( with rim tape running over the rubber on the rim loc ) fit the washer and nut losely on the rim loc bolt stem by at least 4 or 5 threads fit the tube as you normally would, push the rim loc stem fully up ( so that the nut rests on rim )do not let the rim loc stem receede into tyre ) refit the other tyre bead and inflate the tyre and seat the beads on the rim , tighten the rim loc nut and the valve stem nut
make sure that that both rim loc and valve stem are straight when inflated and tightened
refit your wheel
cheers pauly46
Jun 08, 2011 | kawasaki Motorcycles
How do you unlock a kenmore elite cooktop?
You can do this by:
Check the oven display to see whether the screen says "LOC." When "LOC" is displayed, the oven lock is activated and the door cannot be opened. You need to make sure it is locked so you do not mistakenly lock the door.
  • 2 Press and hold the "Stop" button on the oven control panel until "LOC" disappears from the display. Some oven models have a button marked "Oven Lock," which should be used instead of the "Stop" button.
  • Lock the oven again by pressing and holding the "Stop" or "Oven Lock" button until "LOC" appears in the display
  • Feb 03, 2011 | Kenmore Elite 44173 30 in. Electric...
    ERR LOC on display
    Your door lock switch needs replacing.
    Jul 07, 2010 | Frigidaire GLTF2940ES Front Load Washer
    My ge profile range will not operate loc appears when you try to put it on bake
    Hold the 9 & 0 down together till the loc on goes to loc off. About 5 secs.
    Jan 27, 2010 | GE Profile 30" Self-Cleaning Slide-In...
    LOC Blinking
    Control Lock
    To avoid having someone accidentally start or stop the
    washer, press Options and Select at the same time and
    hold for 10 seconds until “LOC” is displayed alternately
    with the estimated cycle time. To unlock the controls,
    press Options and Select at the same time and hold 10
    seconds until ”LOC” is no longer displayed.
    Jun 05, 2008 | Frigidaire Affinity ATF7000E Front Load...
    Washing Machines Logo
    264 people viewed this question
    Top Frigidaire Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
    J. Bradshaw
    Archie Ferrarini
    Archie Ferrarini
    Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
