Question about Solis Palazzo Espresso Machine
I have lost my instruction manual and the last triangle light is on what does it mean and how do i fix
  • 1,089 Answers
Descaling the Palazzo: The Palazzo is programmed to descale the boilers on its own, when set in the correct mode. You program the machine to descale it’s self, do the following. With the machine turned on, push and hold the left 2 buttons (clean and pre-ground). This should light the top right red indicator light. Mix your descaling crystals in a glass of warm water then add to 32 to 48 oz in your water tank. Next, have a container that can handle about 2 quarts of water under the steam wand, or have the machine positioned next to a sink. Next open the steam knob on the right side of the machine. You should hear the pump turn on and pump about 2 to 3 oz’s. of water through the wand into the container. The pump should turn off and there will be a wait of about 2 minutes. The pump should turn on again and more water will come out. It will do this until it has completely drained the water tank. Do not interrupt this cycle until the machine has stopped on its own. When it does stop, all lights on the bottom will flash. Rinse out the water tank and refill with fresh water. Place the water tank on the machine again, and then close, and then open the steam knob again and let the water just flow through the boilers until it is emptied by the machine. Don’t turn off anything until the machine stops on its own. This will clear the descale light. Refill the water tank again with fresh water, open the knob on the right again to prime and when the red light goes out, your ready to go.
Posted on Sep 09, 2010
SOURCE:
I bought the Polaroid Pogo mobile printer.when I first used it, it worked well.today I tried to use it and it is just not working. My phone seems the picture but the printer gets a red flashing light how...
That depends on which red light is flashing. If the battery light is flashing, that means the battery is exhausted. Fix it by charging the battery.
If the status light is flashing red, that means the paper is jammed. Fix this by opening the paper door and pulling out the media. Full instructions are on page 3 of the manual.
The battery light is the one marked with a battery. The status light is the one marked with an exclamation point inside a triangle.
Feb 12, 2012 | Cameras
I've lost my Audi A4 manual and need to know what this signal means. There is a triangle with an ! in the middle of it and a circular arrow around the triangle. I sure it means repair something but...
Hmm... Does your Audi have the old version of the Tire Pressure Monitoring System? (I am guessing because it sounds VERY much like the 'icon' display that GM uses for warning the driver that tire pressure is low (or too high). Otherwise, ignore me...
Aug 08, 2011 | 2004 Audi A4
What do symbols mean i lost my remote and instruction book.triangle,snowflake,pan with drop above,3 blade fan
Triangle = automatic
Snowflake= cooing only
Pan with drops = dehumidifying mode
3 blade fan = fan only (no heat/cool)
Aug 18, 2009 | Heating & Cooling
Fisher price dvd player - Need instruction manual
Check the Fisher Price website for an instruction manual. My daughter has one and when you plug it in and the red light is blinking that means the battery is charging. It has a battery pack inside (not removeable) that needs to be charged for 8 hours before the first use, but I'm guessing yours is used, so just let it charge until the light goes off.
Jun 10, 2009 | Televison & Video
RED LIGHT
Hello Ms; The red Triangle lite means you need feed them toner, they are hungry !
Feb 23, 2009 | Sharp AL 1631 Copier
Hello i got a AMANA 9,000 BTU and the light its blinking of the triangle and i lost the manual of the AC can you tell me what can i do i cant turn on my ac
I have the Maytag version of this machine and the blinking triangle light means the water tray is full. The machine won't operate until that water has been drained -it's the little black tube with the plug at the bottom behind the machine. Pull the plug, tip it down (preferably with a shallow pan underneath to catch the water) and drain as much as you can. Once you've done this, put the plug back in and it should start.
Jan 24, 2009 | Amana Haier AP095R Air Conditioner
Lost instructions
You can get a free dowloadable manual from http://www.cerinicoffee.com/Saeco_User_manuals_free.asp
to look up what the different lights mean.
Jan 17, 2009 | Saeco Incanto Classic Espresso Machine
Solis Palazzo Espresso Machine Logo
336 people viewed this question
Top Solis Coffee Makers & Espresso Machines Experts
graybeard32301
Pierre Laplante
Ekse
Are you a Solis Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
