Kenmore microwave model 665.69682992. I am attempting to replace the door on this model. I ordered the new door but find that the hinges are installed in the new door and cannot figure how to get the new hinges off or the old hinges off. Can you help?
Doug Schmidt
I am looking to replace my Kenmore model 665.61612100 combination microwave with an updated model of the same size and specifications. Any suggestions???
This appears to be an Australian model and these are the only spares I can find. They do sell the latches. If the hinges are damaged and causing this, you will feel movement. Looks like it is time for a new one.
Below is the solution to replace your microwave door.
Unplug the oven from the outlet and/or shut off the gas valve. Open the old door completely and unlock the hinges by pushing the hinge out toward you and down toward the door. Slightly close the door and lift the door up and toward you.
Install the new door. Make sure the wall oven door hinges are aligned to go into the rectangular wall oven slots. Place the hinges into the slots. The hinges should "catch" on the slots comfortably.
Ensure the door is fully opened and push the hinge locks into an upright position. The two hinge locks should rest on top of the two hinges that are inserted in the wall oven slots.
Close the door and open it several times to make sure the door is properly opening and closing. Replug the oven back into the outlet and/or turn the gas valve back on.
The door should come off fairly easily. All you have to do on MOST microwave ovens is open the door all the way and lift straight up at the hinges. The door will come off the hinge pins.
On some models, there may be a small hinge pin on the top hinge that you remove, then lift up.
You may have to remove the grill panel above the door (if equipped) to allow for clearance for the door to come off.
If you have questions, please let me know. I hope you find this helpful.
You will probably need to take the MW down and remove the outer case to access the hinge for the door.
just received a new door assembly for my Kenmore microwave and spent
about an hour searching for help with installation to no avail. , but managed to replace it by prying the small
pin out with a flat head screwdriver and removing the door. I reused
the pin (after straightening it), and it works great.
The door handle is secured with the two screws from inside of the door.
In order to access them you have to remove the inner door frame. You
can find how to remove it in the video clip from one of our previous posts.
The door should simply come off by opening it all to way and lifting straight up at the hinges, The door will lift off the hinge pins. On some models you may have to remove the upper grill above the door (if equipped). If you still have questions, please let me know. I hope this helps you.
I have the exact same problem and the cost for a tech to replace the door is $80 less than buying a new one. They have to remove the unit from the cabinets and pull off the exterior box to unscrew the door hinge. Mine is only 3 years old. I also bought a new oven range. Never really use it. Decided it was time to use the self cleaning. It did not work. $280 to put a new board in. 4 months later I went to clean it and again it did not work. The f*^ing thing only cost $500. Decided Easy off will have to do. Kenmore s*&ks
As for the door... I very CAREFULLY used super glue/ gel and it did the job!
Depends on the door. It likely can be adjusted they have 2 screws on the door bracket you may have to remove the cover to see them. But it also needs to be checked with a leakage meter to make sure its not leaking.
RadioShack used to make a low cost meter not certified or anything but a good way to see if its leaking.
The first piece of advice would be not to remove the door from the oven or tamper with the hinges. The alignment of the hinges is important to prevent microwave leakage, which can lead to burns and damage.
You can usually find exploded views and order parts by entering your model number here at the Sears parts site.
A full Sears/Kenmore model number has 3 digits, a dot, then 8 more digits, such as ###.########
Normally
you have to separate the door panels (as shown in the attached photo)
and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
The part number for a new handle is 820941 and costs approx. $19. If you already have the part and are wanting to install it follow these steps:
You can either do this with the door in place, or remove it. To remove it, you open the door all the way and push up at the hinges. The door should lift off the hinge pins.
1. On the back side of the door (the side that faces the interior of the oven) is a plastic facing around the perimeter of the glass.
2. There should be a series of slots or grooves around the facing that you can place a small screwdriver in.
3. Carefully (I cannot emphasize this enough) lift around the facing until it comes loose. You may not have to remove it all the way around the door. Sometimes you can gain enough access by lifting on the side where the door handle it mounted.
4. Under the door facing are the mounting bolts (or screws). Remove broken handle and install new handle.
5. Reinstall components in the reverse order as stated before.
If you are waiting to order the part for your oven, you can get it at repairclinic.com. The part will be shipped directly do you for a nominal shipping fee.
This should be a fairly simple repair that only takes about 10-15 minutes.
Again, be careful with the door. If you break it, a replacement door costs over $200! Good luck and let me know if I can help further.
The door comes off in a very simple way. Now...I'm speaking from the perspective of MOST microwave ovens. All you should have to do is open the door all the way to the left and lift straight up. The door has mounting pins that fit into a couple of hinge pin holes. If your oven is equipped with an upper panel grid, you may have to remove it, so the door will have more clearance. Putting the new door on is just as simple as lining up the pins in the door with the hinge pin holes and setting the door in place. Close the door slowly to make sure the pins are aligned with the holes properly. If not, the door will fall off while attempting to close. Let me know if this is helpful to you.
