As long as this worked for you, your good to go. Just be aware that when you stretch the roller material that surrounds the barrels, the chance of them falling off is great. The hot water and dryer heat from the coils can loosen them and if they fall into the base and get into the discharge section, you just messed up the pump, etc.
Remove all of the dishes from the lower dishwasher rack.
Pull the lower rack out of the dishwasher so that it rests on the dishwasher door.
Lift the lower rack up and out of the dishwasher.
Place the new lower dishwasher rack on the dishwasher door, then push it into the dishwasher.
Upper Rack
Extend the upper rack as far as it will go.
Remove the two plastic end caps, located on the end of each dishwasher arm. To remove, insert a flat-head screwdriver between the arm and the tab on the outside of the end cap, then lift the tap to remove the end cap. Pull the upper dishwasher rack straight of out the arms to remove.
Insert the rollers on the bottom of the new upper dishwasher rack into the rack arms, then push the rack completely into the dishwasher. . Align the end caps with the ends of the arms, then push the end caps into place.
Upper Rack
Welcome to "Fixya" ! You can find these lower rack support roller & clip assemblies at "repairclinic.com" for around $10ea.
Their part number is 1156665. They are really easy to change as you may already know, they snap in place. Hope that is the answer you where looking for, let me know. Thanks for visiting "fixya" with your inquiry. Please take a second and rate my answer accordingly or if more assistance is needed post a reply.
Good luck.
Macmarkus :)
One option is installing stainless steel washers on the rack supports that screw into the side of the tub. The rack falls down because there is too much "slop" with the rack...a couple small washers to space them tighter normally does the trick.
(http://www.geappliances.com/service_and_support/parts/) the correct # for your unit is pdw7880n10ss just enter your model #(under repair or replacment parts)the site will walk you thru the rest.when you get to the parts list make sure you use the diagram to match your part exactly(click the red box at top of page)hope this helps.thanx for using fix-ya!!!
