Several of my customers are having the same problem here in New Mexico. If your air temperature is around 95 degrees or higher the plastic the caps are made of becomes too pliable to break off when the nail is fired through it. If you cool or freeze the cap roll, the caps will break off however this usually impractical. Get in the habit of moving the gun forward after firing a nail/cap to break the cap off. If you pull up or backwards you get a string of caps pulled out of the gun.
