AYou're out of Toner! Well, you're actually probably not ALL the way out...how about a little trick that'll make sure you get the most out of that toner? It's as easy as taping a picture to the wall. Almost. Remove the toner cartridge from the printer. You may have to also remove it from the drum to see and access both sides of the toner. You will see on each side a round clear little "window". Cover this (both sides) with tape, masking tape works well, just not anything clear like scotch tape, that won't work. We are tricking the printer into thinkiing the cartridge is full, so it will print you at least a couple hundred more pages this way. When your print quality goes down, then you know it is time to change your toner for real. Enjoy! I also recommend a refurb toner, Brother brand is too much... a waste of money. You can find refurb for about $25.
