Black & Decker 220 Watts MX77 PowerPro® Hand Mixer Logo
Posted on Nov 12, 2017
I was using this mixer and it suddenly stopped working. This was some time ago and I think it was trying to work with too heavy (thick) a load. Currently it does not appear to be receiving power to any part. We opened the case and there does not appear to be anything lose or burned. Any ideas? Black and Decker MX78WS type 1
5 Related Answers
Anonymous
  • 274 Answers
  • Posted on Jul 15, 2007
SOURCE: Replacement beaters for hand mixer
Black and Decker now has several store outlets all over the country. They are even online. You can order directly from them. 1-800-544-6986
Anonymous
  • Posted on Apr 07, 2009
SOURCE: Beater broke apart
You can visit http://www.prodprotect.com and click on the Name Brand of product, under Parts & Accessories click on the Contact Us. Once this page has loaded, click on the link at the top of page that states 'To order accessories click here'. If the model or part is not listed on the website, then call 1-800-738-0245 (Monday-Friday, 8:30 a.m. to 8:00 p.m., ET) for price and availability. All major credit cards are accepted. Have the model number of your product when placing the call.
Or you can visit www.fox-international.com or send an e-mail to [email protected].
Anonymous
  • 143 Answers
  • Posted on Sep 14, 2009
SOURCE: Describe your Black & Decker Gizmo
try purchasing another
Lance Hill
  • 1739 Answers
  • Posted on Feb 06, 2011
SOURCE: One of my beaters broke.
For some reason, although you can find this mixer offered for sale, there is no information available for it on the Black & Decker websites in the USA or Canada.
I did find one mixer on the official Black & Decker parts site, which may be similar, with replacement beaters available as Part No. 177177-00 at $12.95 a set:
http://www.foxsales.ca/accessories.asp?modelnumber=1196
Your best option may be to use the Black & Decker Service Center locator to locate your nearest sevice center. This is a part they normally would stock and a quick telephone call should be able to determine availabilty and price.
http://www.blackanddecker.com/Service-Centers.aspx
Lance Hill
  • 1739 Answers
  • Posted on Jun 22, 2011
SOURCE: replacement beaters for Black &
Replacement beaters may be ordered online from this site:
http://www.directpartsandproducts.com/mixers-mx45-c-1_510_528.html
Mixer stop working powerless
Does it work on liquidy content? If it does the reason for not working could be the mixer too thick for its power and may burn motor.
When I turn on my Kitchenaid mixer at any speed, it ramps up to high speed and then shuts down after maybe 30 seconds.
You need a reputable repairman. My gears were stripped after trying to mix a very thick dough. It would only work on high speed. After it was repaired.... I still use it, all the speeds work, and that has been 15 years ago. My mixer was at least 8 years old at the time of the "stripping".
My Preeti Mixer grinder stopped working 750 watt, what could be the solution? It worked for two months after repeatedly pressing load protection button but now completly stopped responding. Can I bypass...
Your circuit breaker (load protection button) was popping for a reason and that reason has evidently gotten much worse. Possible causes are a short circuit in the wiring of the motor or a heavy mechanical load on the motor such as a bad bearing. Here is the service manual for your mixer. It contains all the information you need to fix your problem.
http://lib.store.yahoo.net/lib/mendingshed/kitchenaidservicemanual.pdf
Once you have isolated the problem here is the parts list so that you can search the internet by part number for the replacement part.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%208212369.pdf
Bob
1helpful
2answers
Mixer quit working
Quite likely you overloaded the capacity of the motor and it simply overheated. The brushes inside the motor may be burned out/corroded. I suggest putting a light load on it and seeing how it performs. Often, when this kind of thing occurs, a bit of light duty use will get the motor back into good working order. But be careful to not over-tax the unit again. There are several different KitchenAid mixers on the market, some nothing more than ornamental, all the way up to commercial-grade.
1helpful
2answers
Under a heavy load, the mixer began clunking once per revolution
Disassembly and inspection is the only way to verify what it is. It sounds like you are correct. I have bought parts very reasonably on line and repaired our K/A mixer. The better sites ( I think I used appliancerepair.com) have exploded diagrams. If you are tearing into yours, these are invaluable, and when you get to the broken part, you'll have a name for it.
Best regards, --W/D--
2helpful
Bread dough hook slips when mixing
This is not a solution but I think you have a serious problem you might have sheared some gear teeth whent the mixer jammed and it only manifests itself under a heavy load, I would take it to a repair guy, those mixers are expensive and it would be worth it.
Kitchenaid mixer 45ss
I dont know much about them but If you cannot get it repaired I do have a lift bowl stand mixer that I bought without the bowl or attachments that I would sell for $80.00 Or I will buy your attachments. Thanks, Mark.
West Bend Model 41125 Suddenly Stopped under load
If the mixer does not work under load, then check motor , bearing , and control board.
If the mixer is less than one year old call manufacturer at the number listed on the owners manual.
To get parts for your mixer you can contact West Bend Appliance Parts - Bettervac 1-800-675-9491
Dough Hook Stops moveing under heavy load
Does the mixer work in any other speeds?Are you mixing pizza dough and in what speed?I service these mixers alot--i work for hobart.It sounds to me like you have a sheared key on one of the shafts.The mixer doesnt have a clutch.
Top Black & Decker Food Mixers Experts
CJ Rock
CJ Rock
Stan Ford
Are you a Black & Decker Food Mixer Expert? Answer questions, earn points and help others
