Select the "Start Menu."
Click to select "Control Panel." This will open a new window with several clickable options.
Choose "System and Maintenance," typically located near the top left-hand corner of the Control Panel
Click to select "System" from the new list of options
Look for the CPU's stock speed as indicated under the "Processor" heading. This is a ballpark, relatively close estimate of your computer's CPU speed, as provided by the manufacturer.
Checking the Stock CPU Speed in Windows XP
Click the "Start Menu.
Right-click on "My Computer."
Select "Properties." By default the Properties window will usually be set to the "General" tab, but if the window is set to a different tab you'll need to click on the "General" tab located near the top of the window.
Check the CPU rating as listed underneath the "Computer" heading.
Determining Real-Time CPU Speed
Go to CPU Speed Professional's website (see Resources) and download "CPU Speed Professional."
While other free CPU clocks exist, many are beta programs with glitches and unwanted bugs. CPU Speed Professional is well-known and reputable, receiving the "Vista 5 Star Software Award" according to its website.
Install the recently downloaded
" http://download.cnet.com/cpu-speed-professional/3000-2086_4-10833139.html "
file by double-clicking on it and following on-screen prompts to complete the automated install procedure.
Open CPU Speed Professional.
Click "Test Your Speed" on the main program interface.
A real-time, active measurement of your CPU speed will appear numerically, and CPU Speed Professional will also display your CPU speed on a stylish meter for easy visual comprehension.
hope this helps
***Bios Revision A02***
Service Tag: JZW0S0J (I AM UNSURE AS TO IF THE 0's ARE NUMBER 0'S OR LETTER O'S)
I Have Just Flashed The BIOS With The Update From Dell To Version A12, Still No Change. By The Way, The CPU Is 533Mhz FSB If This Helps In Any Way???
