Freezers Logo
Posted on Sep 08, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My upper shelf is not keeping things frozen when the bottom shelfs are.I cleaned and keeped unpluged for a day and it still does not work.
Anonymous
Level 3:
  • GE Master 43,501 Answers
  • Posted on Sep 08, 2010
Anonymous
GE Master
Level 3:
Answers
43501
Questions
0
Helped
10844451
Points
101584
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
How to remove bottom shelf to clean inside bottom of freezer?
Good Morning Wayne,
I see that you want to remove the bottom shelf of your Frigidaire freezer, to clean inside the bottom of your appliance. To remove the shelf, you will pull it out and lift it up. If you are having troubles getting the bottom shelf out, I suggest contacting a local authorized technician for further assistance. They will be able to diagnose exactly what is causing the shelf to stay inside your freezer. Hope this is helpful.
-Best Regards-
WP
How to defost inside shelfs
The best way to defrost is to empty it, unplug it, prop open the doors, and put a fan blowing on it. This could take a day or more. If this has been pretty bad for a long time you might have wet (and frozen) insulation (inside the walls of the freezer where you cannot see it). If so, you should give it an extra day or two to drip out. You might also have a bad or dirty seal around the door. Clean this thoroughly, and inspect it closely to make sure it seals well. Good luck.
Our freezer sat in the garage unused and unplugged for about a year. Now we are ready to use it so we plugged it in. Its been on about a week now and its still not getting cold inside. Actually I...
something easy to try is to clean the evap. usually on the bottom. warm soap and water, or compressed air usually does the trick. it's the easiest thing to try.
Not freezing on top shelf of door
try to replace the Styrofoam cup then put on the top.. if the same happens.or it will be frozen it means styrofaom is .................................. then use another...
1helpful
Upright freezer. I can put a cup of water in the
Is any thing infront of the fan or vents?
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Feb 17, 2010 • Freezers
Admiral upright freezer dripping water inside on top
Hello.
I can help. Once we notice anything different from before we start becoming more aware of small variations. Regarding things on the top shelf warmer than on the bottom, this is always true because, "warm air rises and cold air falls". If you want the top shelf colder turn the thermostat to the next colder setting, always a good idea in the Summer season anyway.
Even though your gasket looks good, a ten year old gasket is not as pliable as a new one resulting in the moisture problem you describe. I would begin by applying a thin coating of vaseline to the gasket once a week for a month. This little trick of the trade will often work. If it doesn't improve the situation do replace the gasket.
Food is only frozen on bottom shelf
dkburing,
You said, the freezer is only keeping the food frozen on the botton of the freezee. It is cold, but only like a refrigerator.
We need more info,
What is tour brand,model number and the year or age of the fridge.
Waiting for your reply
Huuum
Oct 09, 2008 • Freezers
Not freezing equally
Look for frost build up on back wall at bottom the auto defrost may be out. Check if the evaporator fan is blowing. If not it's stuck by something or needs replaced. If not The sealed system may have a leak or restiction causing it to only work closest to the evaporator i.e. the lower shelf.
3helpful
Upright freezer not cooling
The model number would help but it sounds like a sealed system leak or restriction. If thats the case I would not suggest trying this yourself. The water should freeze overnight and the frost should keep going to all the shelfs that have coils in them.
Apr 16, 2008 • Freezers
1helpful
Freeze on bottom but not on top
when you plug it in do you ear a fan running if not plug the freezer on.and at the bottom of the freezer gently hit were you have a grill sometime the fan motor gonna start running and circulate the cool air if it work keep and eye on it for a few days take care cheers
Top GE Freezers Experts
ZJ Limited
ZJ Limited
Jay Finke
Jay Finke
Are you a GE Freezer Expert? Answer questions, earn points and help others
