Question about Power Acoustik Car Audio & Video
I have a PA A3000DB when it turns on it goes straight into protect for a few seconds the comes out of it. when the gain is adjusted the slightest bit there is a really bad his/whistle out of the power supply fets and then a loud "pop". i have went through everything and it all test out good...IE:the fets, entire drive circuit, capacitors,everything checks out and reads good on the DMM...i am lost as to why this is going on....what should i check or do?
  • 3,083 Answers
This sounds like a cap breaking down to me, under a load. Ohming out caps doesn't stress them, and they can still read good. I would concentrate on the electrolytics, especially the larger ones, in the power supply, as you suspect. Depending on the age of the device, sometimes techs just go ahead and replace them all, just to ensure a solid, lasting fix, since caps are the only really time sensitive components.
Good luck, hope this helps, and thanks for using FixYa.
Posted on Sep 08, 2010
SOURCE:
So i have installed my amp, epicenter, all wiring is done, hace great ground.. But once i turn my car on to sound check everything starts fine but after turning up the volume a bit.. My amo goes into...
It sounds like you have your gain to high. best way to solve this is by turning the gain way down to - or lowest number , then turn everything on and upto the volume you desire, then slowly up the gain. also avoid using bass boost, I agree it sounds great but it puts strain on the amp and shortens life in the amp. with the bass boost off, you can adjust others (not the gain) to get bass.
Hope this helps
Jan 26, 2013 | Car Audio & Video
My bass cuts when playing but goes back on after a few seconds.
that because you have a loose ground to your amp or not the right size wire but check your ground on the amp it will overheat and turn off to protect itself .
Apr 13, 2012 | JBL PRX 518S PRX518S Powered Subwoofer PA...
A3000DB Car Audio Amplifier: I hooked it up.It played for ten mins. Now no soun...
no, check your speaker wire inside sub box check your ground wire and you might need to wire your subs in series
May 17, 2010 | Power Acoustik A3000DB Car Audio Amplifier
Tv switched itself onto standby and now will not turn back on. tried unplugging it and plugging it back in but it still won't come off standby. when you press the button on the remote it goes green for a...
unit seems to go into protect mode.Theres very little that can be done..There is good chance unit needs to be checked at a repair shop.Try to find one that is authorized for your particular brand if possible
Aug 05, 2009 | Televison & Video
Peavey Bass amp 115
HI Subicbay,
ADjust your Gain setting to limit just enough so the amp does not go into Protect mode. Turn your Gain all the way down, then crank up the bass from your system. GRadually turn up the gain until you trip on protect. Turn the gain back a notch and your set for no more protect.
Oct 27, 2007 | Jensen XA4150 Car Audio Amplifier
Amplifeir keeps turning off
HI K-****, Adjust your Gain setting to limit just enough so the amp does not go into Protect mode.
  1. Turn your Gain all the way down,
  2. then crank up the bass from your system.
  3. GRadually turn up the gain until you trip on protect.
  4. Turn the gain back a notch and your set for no more protect.
Oct 19, 2006 | Jensen JPA460 Car Audio Amplifier
Car Audio & Video Logo
26 people viewed this question
Top Power Acoustik Car Audio & Video Experts
Dalynn Turner
Marvin
Marvin
Professor_V
Professor_V
Are you a Power Acoustik Car Audio and Video Expert? Answer questions, earn points and help others
