Question about Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Thethe tv will not come on and power and theopc is flashing.
    New Friend:
  • 4 Answers
Ok This is how to troubleshoot the TV, there are lights on the front and you are mainly concerned with two of these lights (the power light and the OPC light). I) If non of the lights come on then this is a AC Power failure (There is a loose connection or you need to check the Power/Inverter unit or the Main unit) II) If the power light is blinking at a rate of one blink per min and the OPC light is off (then there is a CCFL backlight problem) III) If the power light is blinking at a rate of two times per min and the OPC light blinks at a rate of one time per min (13V/UR10V failure you need to check the Power/inverter board or the main board). IV) If the power light is blinking at a rate or two times per min and the OPC light blinks at a rate of two times per min (3.3V Main Failure check power/inverter board or Main board). V) If the power light is blinking at a rate or two times per min and the OPC light blinks at a rate of three times per min (UR6V failure check power/inverter board or Main board). VI) If the power light is blinking at a rate or two times per min and the OPC light blinks at a rate of Five times per min (Panel 5V failure check LCD control unit or control panel).
Posted on Sep 09, 2010
  • Janet Dawson
    Janet Dawson Mar 09, 2018
    HI I have a Sharp 42D65U tv that is flashing twice with the power and opc then once with the power in just over 1 sec , not what you said above at every minute. So do you know what this code is. I think I have all the voltages you described but I don;t get the 12v to the t-con board. I just want to know which board to replace or remove and look at more closely to see if any of the solder joints have cracked. Thanks Craig
SOURCE:
I have a 56 in hdtv Panasonic tv will not come on green light flashes 20 times then goes to red. Help, on disability fixed income & cant afford to get repair or new tv. Please help, as soon as poss
Panasonic Plasma TV Repair - Understanding 14 Blink ...
? 8:35
https://www.youtube.com/watch?v=iHBIiRxhe0w
Sep 26, 2014 - Uploaded by ShopJimmy.com
Panasonic Plasma 14 Blink Code Explained with Repair Info How to ... I guess I'll try the SC board and if that does not work simply save up for a new ... The red power led was flashing 12 timespause a few seconds then flash 12 again. ... It powers up and shows the green power light is on, but there's no ...
The power light keeps flashing and the tv wont turn on - TV ...
www.tomsguide.com/answers/id.../power-light-flashing-wont-turn.html
Oct 24, 2015 - More about : power light flashing wont turn ... December 20, 2013 10:12:55 AM ... sound like it is coming on then it shuts off and the red power light flashes slowly. ... 50in Plasma tv power light is flashing 8 times and won't turn on. ...tv to come on bcause the power button keep blinking my tv will not come on.
Nov 06, 2015 | Panasonic Televison & Video
I would like to know the procedure to reset this TV because what it does as the power cord is plugged in the relay click and the power light comes on and then the relay clicks on and off until theOPC light...
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
https://www.youtube.com/watch?v=TR2iWN6b-LY
Mar 13, 2015 | Televison & Video
Replacing a tv fuse 8A 250v with an 1/2-Amp 250v
Load fuses are rated. The ratings will be marked at the PCB, very near to the fuse holder. Do not use a fuse, which have more ampere ratting than specified. It will make things worse. If fuse burns out, as soon as the set is switched ON, be sure that there must be some shorted component/s at the power supply regulator section circuit. Check and rectify the fault first, before inserting an other fuse of same rating.
Mar 01, 2013 | Televison & Video
Need User Manual for Panasonic Viera TH-L37X10S Lcd tv
The manual for theTH-L37X10S is available from Panasonic here: http://www.panasonic.ae/EN/Manuals/TH-L37X10A.pdf . (Note it's the same manual even though the final letter is different.) If the above link doesn't work, start here: http://www.panasonic.ae/EN/Pages/TH-L37X10.aspx and click on the Manuals tab.
I hope this helps.
Sep 12, 2012 | Panasonic VIERA TH-L37X10S MULTISYSTEM HD...
When I turn the set on a picture only lasts a moment then the power lite and theOPC lite flash, both together then the OPC then both... what should I do?
Unplug,replug tv back hour later.To let the tv to reset it self back to factory.The tv should work now.Not than the Tuner board is dead,that the board that,where the incomming broscasting signal cable plug into it.Tries websites like a Shopjimmy.com,Ebay.com to buy a Tuner board for the replacement.
Sep 13, 2010 | Sharp LC-42D43U 42 in. LCD HDTV
How to set clock clok tcr368
Setting the CLOK TCR368 is done by having the unit:
Turned OFF - The power button is located at the top left face of the unit.
Press and hold the CLOCK/DISPLAY/PLAY/PAUSE button for at least 4 seconds. (It is located to the right of the power button at the upper left corner of the unit.) Do not let go of the button.
While holding down the CLOCK/DISPLAY/PLAY/PAUSE button, press the HOUR and MINUTE buttons to the correct time.
Release thethe CLOCK/DISPLAY/PLAY/PAUSE button.
The backup battery is to keep the clok circuit running in case of a power failure and can't be used to power the radio.
With the unit OFF, press and hold the FUNCTION button (located between the ipod slot and the snooze button) for at least 2 seconds. The display will flash either 12 hour or 24 hour depending what mode it is in.
Release the FUNCTION button and press it once to change the mode.
Press again to cycle between the 12 hour and 24 hour mode.
When the display indicates the mode you prefer, simply wait 2 seconds for the clock to go into that mode without pressing anything.
Sep 20, 2009 | Digital Products International Clok Smooth...
Sony bravia-unable to tune in video channel via dvd
thethe wires have to run out of your cable box into the dvd recorder then back out to the tv,try rehooking it up
May 19, 2009 | Sony BRAVIA KLV-40U100M 40 in. HD-Ready...
Sharp Aquos LC-37GD6U 37 in. LCD HDTV Logo
2,885 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
