Try cleaning the surface of the drain hole where the flapper fits. There might be crud causing it to not seal. Sometimes the flapper itself is not large enough (or too large) to properly fit the hole. If no good you might try weighting the flapper. Not easy to do. You'll have to pull the flapper, dry it completely find the right adhesive place the weight just right. And hope that works. Good Luck...
SOURCE: Kohler 1-piece flush valve seal replacement.
That is a tricky one. Tighten the tabs, twist into place, then tighten a bit more. They are a pain in the a$$, but with patience you will get it done. Good luck
SOURCE: not the float
Had a similar problem with a Wellworth after changing out all the replaceable parts. The new triangle gasket + nut kit was missing the flat anti-friction ring needed to allow the plastic nut to be hand tightened enough against the rubber gasket - without the ring the friction stops the nut turning, and you get a leak because there isn't enough pressure on the gasket. Retrieved the old ring from the trash & put it in - works perfect now! not sure if this is your problem too, but you might want to check the locknut / gasket tightness & seal.
SOURCE: My 703 Kohler toilet has
Hi, am afraid you have to get a new flush assembly as you have rightly said which is the proper way to solve the flapper problem..
SOURCE: Kohler toilet.............flapper leaking, so
Hi lip58122
Get a piece of wire a couple of feet long (straightened metal coat hanger) and make a small hook in the end, insert the wire hook into the flapper hole and turn the wire a few times in a circle...you are trying to wrap the bag around the hook, if sucessful you will be able to remove the plastic bag.
Please take time to rate me
