OP post in English. please. NO Hablo.
"I have a laptop Toshiba, the problem is this: Do not turn on anything disconnect the battery, I leave the ignition button and nothing, " google translated"
This PC is 11 years old. came with VISTA OS.
All AMD PC, and street value USA of $5 USD. bad.
I think you are saying the PC is dead.
is the screen black?
is the fan silent?
is HDD silent.?
if Just a black screen?ONLY these CCFL LCD screen back lamps, do not last 10 years.
take a flashlight and in a dim room and PC running,
and shin the light on the screen, see data now.
yes, then that is dead CCFL.
easy no?
as seen here. (see photos?)
https://pcdied.com/monitors_and_screens/flash-light-trick.html
Compruebe d.c. La fuente de alimentaci?n y el tomacorriente de pared tienen energ?a y esa d.c. cable conectado a la computadora port?til. No hablo espa?ol, as? que esto no puede ser traducido correctamente.
SOURCE: TENGO UN PROBLEMA MI PORTATIL
check you have correct P.S.U. for your machine and it has correct polarity and is connected up correctly(look for small "arrow" on side of connector)if the P.S.U. is not original
