Pull the sd card out and look on the left side with the card facing you. You will see a slide switch on the left side. It is probably in the down position (locked). Move the switch up and the card will be unlocked. Done!
Testimonial: "Simple question, simple answer. Thanks!"
The problems ("memory card locked") that may arise due to several factors such as the following:
1.try using a 4GB SDHC card with an old camera that was made before the SDHC format out.
solution: replace it with the appropriate memory card
2. problems with the buttons on the side of the card, and an internal switch to the camera.
solution:There is a white sliding button "ON" the side of your memory card, slide up up to "UNLOCK" the memory card
3. or the problem may also arise from simple formatting problems if the card has not been formatted in the camera (this will delete the contents of the card).
solution: you will have to reformat the card. WARNING: THIS WILL DELETE ALL DATA ON THE MEMORY CARD!!! So make sure you connect it to the computer ASAP and copy all of your data over that you want to keep. Then through the menus on the camera, reformat the memory card
hope that helps
have anice day :)
