E-Machines (308714) Motherboard Logo
Posted on Sep 06, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Intially, the computer would just turn off anywhere from 30 secs to 5 minutes. Changed the power supply and now the monitor gets no signal
Anonymous
Level 2:
New Friend:
  • Expert 115 Answers
  • Posted on Sep 06, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
115
Questions
0
Helped
18686
Points
307
Please make sure that you've connected the power cord to the board. please also check it the processor heatsink is locked flat properly.
Anonymous
Level 2:
  • Expert 37 Answers
Anonymous
Expert
Level 2:
Answers
37
Questions
0
Helped
2466
Points
103
The power supply you installed does not have enough power to run your video card
How do I get the fault codes up on a Panasonic split air conditioning system CUE24FKR
14.2.2 To Make a Diagnosis1 Timer LED starts to blink and the unit automatically stops the operation.
2 Press the CHECK button on the remote control continuously for 5 seconds.
3 "- -" will be displayed on the remote control display.
Note: Display only for "- -" (No signal transmission, no receiving sound and no Power LED blinking)
4 Press the TIMER ? or ? button on the remote control. The code "H00" (no abnormality) will be displayed
and signal will be transmit to the main unit.
5 Each press of the button (? or ?) will increase error code
number and transmit error code signal to the main unit.
6 When the latest abnormality code on the main unit and
code transmitted from the remote control are matched,
Power LED will light up for 30 seconds and a "beep" sound
(continuously for 4 seconds) will be heard. If no codes are
matched, Power LED will light up for 0.5 seconds and no
sound will be heard.
7 The breakdown diagnosis mode will be canceled unless
pressing the CHECK button continuously for 5 seconds or
operating the unit for 30 seconds.
8 The LED will be off if the unit is turned off or the RESET
button on the main unit is pressed.
Diagnosis
display Abnormality / Protection control Abnormality
Judgement Emergency operation Primary location to verify H00 No abnormality detected - Normal operation H11 Indoor / Outdoor abnormal communica
tion > 1 min after starting
operation Indoor fan operation
only • Internal / external cable connections
• Indoor / Outdoor PCB H14 Indoor intake air temperature sensor
abnormality Continue for 5 sec. - • Intake air temperature sensor (detec
tive or disconnected) H15 Outdoor compressor temperature sensor
abnormality Continue for 5 sec. - • Compressor temperature sensor
(detective or disconnected) H16 Outdoor Current Transformer open cir
cuit - - • Outdoor PCB
• IPM (Power transistor) module H19 Indoor fan motor mechanism locked 7 times occurance
continuously - • Indoor PCB
• Fan motor H23 Indoor heat exchanger temperature sen
sor abnormality Continue for 5 sec. O
(Cooling only) • Heat exchanger temperature sensor
(detective or disconnected) H24 Indoor heat exchanger temperature sen
sor 2 abnormality Continue for 5 sec. - • Heat exchanger temperature sensor
(detective or disconnected) H27 Outdoor intake air temperature sensor
abnormality Continue for 5 sec. O • Outdoor temperature sensor (detec
tive or disconnected) H28 Outdoor heat exchanger temperature
sensor abnormality Continue for 5 sec. O • Outdoor heat exchanger temperature
sensor (detective or disconnected) H30 Outdoor discharge air temperature sen
sor abnormality Continue for 5 sec. - • Outdoor temperature sensor (detec
tive or disconnected) H33 Indoor / Outdoor wrong connection - - • Indoor / Outdoor supply voltage H38 Indoor / Outdoor mismatch (brand code) H50 Ventilation motor abnormality 7 times occurance
• Ventilation motor H51 Nozzle lock abnormality 2 times occurance
continuously - • Nozzle H52 Limit switch abnormality - - • Indoor PCB H97 Outdoor fan motor mechanism locked 2 times occurance
within 30 minutes - • Indoor PCB
• Fan motor H98 Indoor high pressure protection - - • Air filter dirty
• Air circulation short circuit H99 Indoor heat exchanger anti-freezing pro
tection - - • Insufficient refrigerant
• Air filter dirty F11 Cooling / Heating cycle changeover
abnormality 4 times occurance
within 30 minutes - • 4-way valve
• V-coil F90 PFC control 4 times occurance
within 10 minutes - • Voltage at PFC F91 Refrigerantion cycle abnormality 2 times occurance
within 20 minutes - • No refrigerant
(3-way valve is closed) F93 Compressor rotation failure 4 times occurance
within 20 minutes - • Compressor F95 Cool high pressure protection 4 times occurance
within 20 minutes - • Outdoor refrigerant circuit F96 IPM (power transistor) overheating pro
within 30 minutes - • Excess refrigerant
• Improper heat radiation
• IPM (Power transistor) F97 Outdoor compressor overheating protec
within 10 minutes - • Insufficient refrigerant
• Compressor F98 Total running current protection 3 times occurance
within 20 minutes - • Excess refrigerant
• Improper heat radiation F99 Outdoor Direct Current (DC) peak detec
tion 7 times occurance
continuously - • Outdoor PCB
• Compressor
Note:
"O" - Frequency measured and fan speed fixed.
The memory data of error code is erased when the power supply is cut off, or press the Auto Switch until "beep" sound heard following by pressing the "CHECK" button at remote controller.
Although operation forced to stop when abnormality detected, emergency operation is possible for certain errors (refer to Error Codes Table) by using remote controller or Auto Switch at indoor unit. However, the remote controller signal receiving sound is changed from one "beep" to four "beep" sounds.
My computer has been working fine. I powered it on today and I had no signal on my Sceptre monitor and the tower was runnning. I unpluged all cables on the monitor for 30 sec. Plugged them back and...
shut your computer down for 1 minutes with the power unplugged, and try it again.
depending on if your savvy with computers or not depends on how indepth you want to be.
You need to determine if your video card has gone bad or not. try to remove everything attached to your motherboard, memory, hard drives, any cables, and see if your screen turns on. Take out any network cards, video cards, modems etc, that is inside your comptuer. So you need to have your motherboard, cpu and fan+ power supply connected, and try to turn it on. If the screen comes up,l something you removed is bad. If it does not, and your computer is running, bad video card.
Most computers today come with an integrated video card, meaning everything is 1 piece. You might be able to bypass your motherboards video card port, by installing a separate card. You can get these at any computer store.
Hope this helps!
2answers
My acer al1511 monitor started shutting down after 2 or 3 minutes, the green power led turns orange(like no signal). if i turn the monitor power button off and back on the monitor works for 30 sec to 1...
Here are the service manual (not usre which model you have, downloads are limit to two per day):
http://elektrotanya.com/?q=showresult&megnev=acer&megnev2=al1511&kategoria=&kat2=all
You need to do some voltage checking make sure you do have 5 and 12v. The caps the secondary DC side should all be replaced at the same time, it may look OK but they can have high ESR, and they also should be low ESR type such as FM or FC series by PANASONIC. You can send me pictures if you want more help, [email protected]
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
After 5 mins the screen will go blank. turn monitor off and then on will work for 30 -60 sec and go blank
your back lights are going out. you need it repaired. it may be the lamps. invertors or power supply. you need to look at the power supply for damaged electronics, leaking crown capacitors. blown fuses and resistors. you need to replace them to make it work
1helpful
No Signal To my Monitor and no beep.
First refix the RAM and Pci graphic card.
Pull cmos cell from mother bord for 15 minutes then put again into its position then all settings are defaults.
Then if still face problem then check with other RAM.
2answers
When turned on, it immediately turns off after about 5 secs. can u help me find solution regarding this? thanks
Sounds like it could be that the lcd is going bad in your monitor. Try hooking up a known working monitor to your computer and if you get the video to stay on then you know the original monitor is bad. If you cant' get the video to stay on even with the known working monitor then you know that the video card inside of the computer is bad.
Monitor warning pc enter power saving mode
Are you using usb keyboard and muse. if so your usb ports are dead
61MP1 turns off after 5-10 minutes
Ryan
I have a 61MP1 that wont turn on. I get the green flashing light to signal power but nothing happens with the plasma. You seem to know a fair bit. A guy in UK said he'd supply a new power board for $500 but wants my old one in return. Sounds like it might be something I can fix here. Any suggestions. Barry
My monitor not turn on when the computar turn on to . and when you try to turn on the monitor its like flash for 1 sec and tune off to black . to turn the monitor on i need to prees the botten 30 time on...
First you sec your monitor power cable is not loos or power in properly if ok then you sec your monitor VGA cable is properly conect to your pc if ok then you disconnect your VGA cable in your pc then you power on your monitor and sec that youre monetor screen. show a masege or not masage like tiis : CHEEK SIGNAL CABLE or NO SIGNAL : if show this signal then you men your display card is not responding or monitor shows nothing then you meen your monitor is faulty then contact any monitor techenican and solve your monitor problem.
1helpful
Monitor light blinks
have you tested the power supply connection feeds? test each connector I think you will find your power supply has failed on either the 5 volt or the 12 volt side more than likely 5 volts are down' the agp adapter needs 5 volts to run. since you have changed out every thing else I would replace that or test your dads power supply in your computer, that should do the trick
Top E-Machines Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Andrew Chrostek
Andrew Chrostek
Level 1 Expert
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
