SOURCE: convert CISCO 7940 to SIP
you need different files to upload by tftp
by example version 8
P0S3-08-2-00.sb2
P0S3-08-2-00.sbn
P0S3-08-2-00.bin
P0S3-08-2-00.loads
OS79XX.TXT (tells the version)
SIPDefault.cnf
SOURCE: Converting Cisco 7940 IP Phone to SIP
Unlocking a Cisco 7940
Method 1:
1) Unplug the phone
2) Plug the phone back in while holding the # key
The phone will soon display “Reset key sequence detected”
3) After several lights flash press the following keys in order:
1 2 3 4 5 6 7 8 9 * 0 #
4) The phone will then ask you if you want to save the network configurations:
Save network cfg? 1=yes 2=no
5) The phone will soon display “Factory reset initiated” and will continue
through the boot up process.
If that process fails to work for some reason there
is a second method.
Method 2
Complete these steps:
The phone will now be reset.
Also see this link
http://www.cisco.com/univercd/cc/td/...tain.htm#93250
SOURCE: My Cisco ip Phone 7940
Solution #1 sure is funny, but however the "not-ringing" is a known bug with Cisco 7940 IP Phones. At IdacomUSA, we will gladly and professionally repair and refurbish your phone and get rid of that problem for ya.
http://idacomusa.com
SOURCE: 'in call' volume cisco 7940
The handsets will eventually go bad. If it is every single handset that you have, the problem is with the system. But if the problem is only with a few of your phones, you might consider replacing the handsets. We at IdacomUSA.com have replacement Cisco handsets for sale at only $25. Hope this helps you out :)
1-800-903-9190
SOURCE: my red light wont go out on cisco 7940 phone, even
Has this just stopped working, or has it never been working?
On the call manager / CME the MWI (Message Waiting Indicator) needs to be configured. This could be undertaken either via the GUI or from the CLI
For instance ...
ephone-dn 30
number 8000...
mwi on
ephone-dn 31
number 8001...
mwi off
and also mapped to each phone to enable MWI status
ephone-dn 1 dual-line
number 111
label Chris
name fred
call-forward busy 800
call-forward noan 800 timeout 10
huntstop channel
mwi-type visual
Complete config details are at:http://www.ciscosystems.com/en/US/docs/voice_ip_comm/cucme/command/reference/cme_m1ht.html#wp1018439
If this helps pls leave feedback
