Question about Samsung HLN467W 46" Rear Projection HDTV
Samsung DLP Check Fan #3
We are getting an error message "Check Fan No. 3"... What does this mean, and how do you fix it?
  • 6 more comments
  • Acrophil May 23, 2008
    Same problem today. Flashes check fan # 3. The green light is flashing red and green.
  • lee98roy Jul 01, 2008
    check fan #3
    check fan #3
  • lee98roy Jul 03, 2008
    where is fan #3 in Samsung dlp TV
    Printed message in red letters that say "check fan #3" after a few minutes the tv turns itsself off.
    where is fan #3 ?
    Message appears on the screen saying "check fan #3" in red print.
    After the fan #3 message the set will turn its self off.
    Our set is very slow in booting up, with a lot of snapping noises when it is turned off.
    Where is fan #3 ?
  • samantha_byd Jan 21, 2009
    my samsung says check fan 3
  • Anonymous Mar 01, 2009
    Fan # 3 message..  We have a big fire going in the fire place..  Going to try leaving the tele turned off for a while until the room returns to normal temp..  Hopefully nothing in the tele is damaged.  :-(
Where is fan #3 in samsung dlp
Posted on Jul 03, 2008
    New Friend:
The THIRD FAN is behind the Digital board where the DVI plug in are
Posted on Dec 11, 2009
    New Friend:
  • 3 Answers
Fan #3 is the LED PCB fan to the back right as you look at the back of the set. You'll have to completely pull the tray out (not hard) and the fan is right there in the open to the right behind fan #2 (the larger fan).
Posted on Apr 25, 2012
    New Friend:
    Problem Solver:
  • 4 Answers
Just replaced fan 3 on hln467wx lookin in the back 1 on the right blows into big fan towards bulb easy to replace
Posted on Jan 12, 2010
SOURCE:
Where is "fan #2" in Samsung dlp hl-r5656w?
I don't know which is fan #2 but if you take the back off, you will see one fan right in front of you. The other is harder to get to. It's the black box inside the silver covering with the holes (in left lower part).
My TV was acting up by having only one color showing until I let it cool down then it would work fine. I cut a hole in the plastic back cover and mounted a bigger computer fan. Just spliced it in the wires of the little fan. Fixed the problem
Jan 26, 2013 | Samsung HL-R5656W 56" DLP HDTV
Samsung DLP TV, model HL67A750A1F fan #3 message then turns itself off
Please check the all fan if working properly if all works fine you have defective board inside behind fan # 3 you need to replace it..
Dec 13, 2011 | Samsung DLP HL-P5663W 56" TV
Samsung DLP HLT 5087s I am getting a number 3 fan error. Now I not mechanically incline can anyone HELP.
POWER SUPPLY BOARD!!!!! Heres link to fix it. http://www.bking01.com/Samsung_HLS5679.htm
Sep 26, 2010 | Samsung HL-S5679W 56" HDTV
Samsung hl-s4666w DLP "Check Fan #2" on-screen message appears before shutting off. How do I fix this?
Look at the Large Lamp fan and if it is not rotating it is bad and needs to be replaced. If is ok then check the other two smaller fans. You do have a bad fan.
Apr 03, 2010 | Samsung HL-S4666W Television
My Samsung 50'' DLP msg "Check Fan No. 3"
You can attempt to remove the back cover, but there is a very delicate mirror in the back. I'd just move it away from the wall, used compressed air to clean out the fans, and put everything back together. Just make sure you don't damage the color wheel or light engine.
Feb 04, 2010 | Samsung HLR5067WX 50" Rear Projection HDTV
Samsung HL-P5063W DLP No. 1 fan problem
Defective Lamp,maybe and Ballast Board may well be the problem it is what turns Lamp on Look on line Encompass Parts Dist 1-800-638-3328 Ballast Board also has small fan mounted in front of it!
Nov 21, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Samsung HL-S5679W Check no. 3 fan message
Their is no more you can do.
You need a professional.
Stop using the TV until it is repaired.
Call the manufacturer to find you nearest authorized service center.
MR. TV Sales & Service Inc
Milwaukee, Wisconsin 53405
(414) 762-8600
Established 1974
Mar 24, 2009 | Samsung HL-S5679W 56" HDTV
Samsung 50" DLP TV
Since the lamp generates a lot of heat, the fans are continuously monitored for correct function. The owner's manual should show you the location of the fans. Make sure that the grills covering the fans are clear of dust and that the fans are clean. Sometimes dirt can cause the fan blades to slow down enough to trigger the safety alert.
Keep us posted.
Dan
Jun 27, 2008 | Samsung DLP HL-P5663W 56" TV
Samsung HLN467W 46" Rear Projection HDTV Logo
5,619 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
