Your drain is clogged. Every time it defrosts the water from the defrost should drain out to a catch basin under the ice box. That drain is clogged. You need to access the drain and clear it.
most cases your freezer drain hole is frozen or clogged, you can try to turn off the unit with doors open for 24hrs. in most cases it will reset by it self. also check door gaskets for open gaps or drain hole is clogged by debris, remove freezer panels to get access to drain hole, clean it with a 1/4 inches plastic tube, you just have to push it in and out. Good luck.
clogged drain,take off back wall in freezer,under the evap coil you'll see a drain hole,melt it out with hair dryer and there is a heater probe you can install into the drain hole,call your local parts store and ask them about it
This leak , is coming from the defrost drain , inside the freezer section , at the back . The defrost drain is clogged with ice . Remove the bottom freezer crisper , and use a hairdryer to defrost the ice . You will see a drain hole where the defrost water is supposed to drain thru . Hot water helps defrost this hole . Once defrosted , use a small hose inserted into the drain hole , to blow thru , to remove built up debris , inside the unseen drain line .
generally means defrost drain is clogged. take out back panel and bottom tray in freezer check to see if there is ice build up ,if so drain is clogged remove ice and run hot water over drain hole carefully run a clothes hanger into hole until water runs through.
Your defrost drain hole is clogged. Look for the drain hole in the bottom rear of the freezer section. Turn off the fridge. Heat the drain hole with a hair dryer and clear the ice. Pour a quarter cup of bleach into the hole.
The drain tube is located in the freezer section. Upon removing the pack panel, you should see a small nickel size hole at the rear bottom within a metal water catching area. Signs of a clogged drain is water at the bottom of the freezer or refrigerator cools insufficently. If your drain is clogged, you should see if in and around the drain-hole and can be become difficult at times
the drain hole could have ben clogged with dirt and now with ice as the water did not drain as it went back to freezing mode. un plug the unit, let the ice thaw for a day, open the rear cover of the freezer and clean the bottom part of the evaporator. you can find the hole at the bottom part of the drain pan. i hope i was able to help.
