Your pump is probably blocked. Do you have an outside area you can get the machine to? If so, drain it by taking the pipe off as described below:
You will have to tilt the machine to access the bottom
of it. The pump will have an incoming water pipe from the drum, and an
outgoing pipe to the drain. These pipes are usually fixed with spring
clips which you press to release (may need a plier here). Remove the
pipe that comes to the pump from the drum.Check for items blocking the
pump via the opening for the pipe. You will probably find a sock or some
other item blocking the pipe. Remove and re-fit the pipe and spring
clip. It should work now.
