GPS Logo
Posted on May 13, 2008
Garmin Escort C550 GPS
Escort C550 GPS
  • Anonymous Sep 26, 2008
    I have the same problem. Does anyone have a solution? Is a reset the only solution?
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jun 23, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
429
Points
It is becoming more often that a sudden message appears filling the screen saying "memory full". I didn't find anything in the instructions dealing with this message. I emptied all added data and information and the message appears untill I pres the OK botton.
Thanks for your help
2answers
Forgot my pin for my garmin c550 gps, have'nt use in a long time.
You must call the factory to verify you have the unit - -and they will reset it remotely - this is to keep a thief from using it.
3helpful
Will not charge c550 garmin
OK, THANKS, THE MOST LIKELY PROBLEM HERE IS THE BATTERY IS DEFECTIVE.
I would like to up date the lateest maps for my c550
Maps are available for purchase either at Garmin's web site, or from your local GPS retailer. Garmin now offers a lifetime map update for one price, which allows you up to 4 map updates per year.
Garmin C550 Locked
Nope. Take the unit back to your security location which you sent when you first got the GPS. Without knowing the PIN or security location, you will not be able to unlock the unit. You will have to send it in to Garmin to be unlocked, and you will have to include your receipt from an authorized dealer.
2answers
Forgot pin number
The only way to unlock a PIN locked Garmin is to enter the correct PIN number, or take the unit to the location at which the PIN was entered. Your only other option is to send the unit to Garmin.
Garmin c550 pin or password
PIN FOR MY C550 GPS
The only way to unlock a PIN locked Garmin is to enter the correct PIN or take the unit to the location at which the PIN was entered. Other than that, your only other option is to send the unit back to Garmin.
Top GPS Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a GPS Expert? Answer questions, earn points and help others
