Hi
Thanks for using FixYa. Error F 35 means ANALOG PRESSURE SENSOR FAILURE- If this failure is displayed then there is any malfunction of the component detected by the Steamer Electronic Board.
1. Check if pressure hose is fixed correctly.
2. Check if the air trap is not blocked.
3. Check if the hose is not blocked
If it still not works then it is a problem with the water level pressure switch operation. There could be a blockage in the air dome or pressure switch hose. The air dome is located on the back of the tub on the left hand side. If the pressure switch hose and the air dome are clear of any blockages, then there is an issue with the water level pressure switch.
Please do rate the solution if the issue is resolved or else post a comment for further assistance.
Thanks
Rylee
Replacing the water level pressure switch worked for me. There are instructions inside the lower right site panel to help confirm this is the fix you need. Also note that some of these machines were manufactured with sensor part # W10156252, which has been discontinued. The functional replacement is part # W10249845, but an alignment tab must be trimmed from the connector to install it. No other mods are necessary.
