Question about Akai PT5598HD 55" Rear Projection HDTV-Ready Television
AKAI PT5598HD will not turn on.
My Akai PT5598HD is 4 years old. The set will not turn on. There's no picture or sound, just a blinking red timer light. Do you have any suggestions? Do you have instructions where part is located in TV and how to replace?
  • kirby2lane May 14, 2008
    Maanita you provided the Sony timer blink codes for Sony. The TV is AKAI. What up.
    Genius:
  • 1,142 Answers
If you got to the following link and search by the model number you will find what your looking for.
Http://www.samsungparts.com/search/search.asp
The part number for the service manual is SM-PT5598HD
As the set is showing a blinking red timer light. you can check the following link out.
http://www.techlore.com/article/15444/
Posted on May 13, 2008
SOURCE:
Hi i recently found an Akai PT5598HD tv in somebody's trash pile they said that someone had cut the power cord and threw it away. they did not want to deal with the hassle. I took the tv and spliced the...
On the power supply board is a tyrisitor and high voltage capacitors 2k most of the time Poor Solder Connection right where AC line connects,you will see it on that board.
Resolder everything and set should come on.
Oct 19, 2010 | Akai PT5598HD 55" Rear Projection...
I have a 55 inch Akai rear projection tv.When I turnit on,the red timer light blink,and that is all.I've heard about this problem on here before.No pic and no sound
on the main board of the tv there is a fuse located if that is faulty this can happen,there are also many other possibilities but check out the fuse first many a times replacing the fuse solves the problem as its very negligible to replace the fuse the cost of fuse is under $1.
Mar 03, 2009 | Akai PT5598HD 55" Rear Projection...
AKAI PT5598HDI 55" PROJECTION TV HAS POWER AND SOUND, NO PICTURE
Open the back of the tv and check Fuses, sound like the high volt over loaded
Jan 11, 2009 | Akai PT5598HD 55" Rear Projection...
AKAI PT5598HD won't turn on
take it to a repair shop and have then look at it. it may or may not be worth the cost of the repair. i dont know what the parts and labor would be on it
Nov 15, 2008 | Akai PT5598HD 55" Rear Projection...
AKAI 54 inch
sounds like your convergance ic's shorted on you.
you can replace the fuse in the power supply and disconnect the conv board and see if it comes on. if so order new ic's and check all resisters for the correct values.
good luck
Jun 09, 2008 | Akai PT5598HD 55" Rear Projection...
Won't turn on
If you're using a DVD player or other component using the Component cable hookup, try unplugging that from the mix, unplug the power cord for the TV from the wall and wait 15 seconds and plug it back in, then power the TV back on. Mine used to do this and I gave up on the component cable option and went back to composite (RCA).
Feb 09, 2008 | Akai PT5598HD 55" Rear Projection...
REAR PROJECTION TV NOT TURNING ON
I just got this tv free and it will stay on for 15-30 minutes and then turn off. Some times it will stay on all day, though, so its kind of weird. I have the 5499HD
Dec 29, 2007 | Akai PT5598HD 55" Rear Projection...
WOn't turn On
I talked to an Akai certified tech who told me the problem is a bad convergence module. The part alone is $400. Fortunately, I purchased mine from Costco 3 years ago. Costco has a 100% guarantee policy that I was not aware of. I called them asking if I had an extended warrenty and they gave me the full purchase price as a refund ! If any Costco purchasers are experiencing this problem and you purchased the TV prior to March 2007 (when Costco changed their policy), you may be able to take it back and get the full amount you paid for it. I turned around and purchased a new, larger Panasonic for under $150 more. It has a 5 year warrenty.
The Akai service number (to reach a certified repair place) is 1-800-726-4405. The Akai people are very good and can direct you to options. For those near Pittsburgh PA, Contact Rosewood Audio in New Castle 724 654-3023.
KW Pittsburgh
Dec 24, 2007 | Akai PT5598HD 55" Rear Projection...
No power to the television
Dont know if this will help, try leaving it unplugged over night, thaught I saw that solution in a blog somewhere a while ago.
Dec 23, 2007 | Akai PT5598HD 55" Rear Projection...
Akai PT5598HD
· http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
· http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 17, 2007 | Akai PT5598HD 55" Rear Projection...
Akai PT5598HD 55" Rear Projection HDTV-Ready Television Logo
312 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
