In case of paper jam, switch off your printer. Gently try to pull out the jammed paper. Dont force too much if in case the paper is jammed very hard.
There should be a paper jam removing window behind the printer. Locate it. Remove the back paper jam removing compartment and pull out the jammed paper from behind your printer.
I hope this solution is helpful to you
Thanks
