Question about Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive
My seagate barracuda 7200 80 gb having s/n: 9qz0c2zz is not recognize by my computer im using windows xp operating system
  • Seagate Master
  • 27,725 Answers
Try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
have secure connections and are not faulty or just replace them they are probably old and faulty ?
good luck
Posted on Sep 06, 2010
SOURCE:
How do i know it is backing up everything?
depending on your operating system this may vary click start control panel you should see system security tab in that back up my computer in windows7or all programs accessories system tools you should see back up in xp after the back up finishes windows will tell you your computer back up was successfull also you could right click on the back up file select properties this will tell you how many GB were used
hope this helps
Apr 06, 2011 | Seagate Barracuda 7200.7 (ST360014A-20PK)...
When I try to instal a windows vista on my computer it says that I should load the hard drive's driver. I don't have such a thing and I can't find it anywhere. I have a Seagate ST3160812AS Barracuda 7200.9...
i was wondering are tying to install additional partition or you wanted a dual boot? or simple want to install WVista completely from scratch? normally what you need to do is hit F12 go to boot menu then your bottable CD should be on the CD/DVD drive already and re-format your hard drive...
Aug 11, 2010 | Seagate Barracuda ST3160812AS...
Seagate barracuda external 500 gb hard drive usb not seen any longer,cables and power okay , tried on three computers
Verify what Drives have been detected by your Operating System by using Windows: Control Panel -> Admistrative Tools -> Computer Management -> Disk Management -> Your Hard disk(s) will be displayed with all existing partitions and any assigned drive letters.
Your external (or internal) drive must be recognized as having formatted partitions that have a drive letter assigned to each required partition.
Hope it helps: let me know how you go!
Dec 30, 2009 | Seagate Barracuda 7200.10 500 GB SATA Hard...
I require a driver for a seagate barracuda 7200.7 160GB hard drive
Seagate and Maxtor-brand External Hard Drives
External drives contain a standard computer hard drive in an enclosure that makes it possible to connect it to in of your computers external data ports (USB, FireWire or eSATA). This makes it easy to add a drive for backup or data storage to any computer with a compatible external data port.', OFFSETY, -50, FONTCOLOR, '#C1C1C1', WIDTH, 225, BORDERWIDTH, 0, JUMPVERT, true, SHADOW, false, FADEIN, 100, FADEOUT, 100, STICKY, 1, DURATION, -300, CLOSEBTN, false, CLICKCLOSE, true, BGCOLOR, '#232323')" onmouseout="UnTip()" href="http://www.seagate.com/www/en-us/support/knowledge_base/industry_terms_glossary/" target="_blank">external hard drives
do not require additional drivers to function in Windows Vista
Microsoft Vista is the successor to Windows XP operating system. ', OFFSETY, -50, FONTCOLOR, '#C1C1C1', WIDTH, 225, BORDERWIDTH, 0, JUMPVERT, true, SHADOW, false, FADEIN, 100, FADEOUT, 100, STICKY, 1, DURATION, -300, CLOSEBTN, false, CLICKCLOSE, true, BGCOLOR, '#232323')" onmouseout="UnTip()" href="http://www.seagate.com/www/en-us/support/knowledge_base/industry_terms_glossary/" target="_blank">Windows Vista
, Windows XP
Microsoft Windows XP is the successor to Windows 2000. ', OFFSETY, -50, FONTCOLOR, '#C1C1C1', WIDTH, 225, BORDERWIDTH, 0, JUMPVERT, true, SHADOW, false, FADEIN, 100, FADEOUT, 100, STICKY, 1, DURATION, -300, CLOSEBTN, false, CLICKCLOSE, true, BGCOLOR, '#232323')" onmouseout="UnTip()" href="http://www.seagate.com/www/en-us/support/knowledge_base/industry_terms_glossary/" target="_blank">Windows XP
, Windows 2000
Microsoft Windows 2000 is the successor to Windows Me.', OFFSETY, -50, FONTCOLOR, '#C1C1C1', WIDTH, 225, BORDERWIDTH, 0, JUMPVERT, true, SHADOW, false, FADEIN, 100, FADEOUT, 100, STICKY, 1, DURATION, -300, CLOSEBTN, false, CLICKCLOSE, true, BGCOLOR, '#232323')" onmouseout="UnTip()" href="http://www.seagate.com/www/en-us/support/knowledge_base/industry_terms_glossary/" target="_blank">Windows 2000
, or Mac OS X
Mac OS X is the operating system that is produced by and comes standard on Apple computers.', OFFSETY, -50, FONTCOLOR, '#C1C1C1', WIDTH, 225, BORDERWIDTH, 0, JUMPVERT, true, SHADOW, false, FADEIN, 100, FADEOUT, 100, STICKY, 1, DURATION, -300, CLOSEBTN, false, CLICKCLOSE, true, BGCOLOR, '#232323')" onmouseout="UnTip()" href="http://www.seagate.com/www/en-us/support/knowledge_base/industry_terms_glossary/" target="_blank">Mac OS X
. These external drives are supported by the standard device drivers that are already included in these operating systems out of the box. Installing Serial ATA drives requires the installation of drivers from the Serial ATA motherboard. Click here for more information on this subject.
http://seagate.custkb.com/seagate/crm/selfservice/search.jsp?DocId=201413&NewLang=en
Oct 25, 2009 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Windows xp will not recognize my seagate barracuda 7200.10 although it is recognized in the BIOS. I pressed f6 during setup and it is asking about the Manufacturer-suplied hardware support disk. Where...
If you have one HDD set it to master with your jumper settings. Try again. If No go than change the cable connector. If SATA HDD than change the connector on the MOBO try another connector. Restart. If still no go than write back
Jul 30, 2009 | Seagate Barracuda 7200.10 320 GB SATA Hard...
Dimension 4700 with Barracuda 500Gb SATA HDD
You have to go online and search then download the drivers for preparing SATA laptop harddrives for installation of Windows XP otherwise during installation it will tell you there is no hard drive found.
Dec 12, 2008 | Dell Dimension 4700 PC Desktop
How to detect two IDE drives with same brand
You need to set one of the drives to be 'master' and the other to be 'slave'.
This is done by positioning jumpers on the back of the harddrives.
Pretty sure that on the drives is explained somewhere how to position the jumper, for several options.
Good luck,
Please post some feedback.
Apr 23, 2008 | Dell OptiPlex GX280 PC Desktop
Disk not being Recognised: Windows XP asking for driver
s cuase u r using ur hard disk with different mother board so u need to format it or u need to get teh mother board cd an dchange the boot sequence as cd-rom and run it
Oct 31, 2007 | Seagate Barracuda 7200.7 40 GB Hard Drive
Hard disk not detected
The problem is that u have done partitions for 160 GB harddisk, so do all the partitions of 40 GB or less than that.
Sep 24, 2007 | Seagate Barracuda 7200.7 40 GB Hard Drive
Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive Logo
260 people viewed this question
Top Seagate Computers & Internet Experts
Ekse
Alun Cox
Argospete
Argospete
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
