YES, IT CAN
no kidding, use mpeg converter, you will find it can convert any video format to mpeg, rock and roll
How to change the recording video type to MPEG?
Mpeg format is very popular for its wide-ranged compatibility with video editor and media player, and its cross-platform neutral capability, meaning the mpeg format can be easily handled not only by Windows OS, but also on Mac. Mpeg is a compression codec used to reduce the space video files take up without severely compromising image quality. And MPEG-4 is the global multimedia standard, delivering professional-quality audio and video streams over a wide range of bandwidths, from cell phone to broadband and beyond.This could explain why so many people choose mpeg format for video editing purpose. It is also no surprise that people would ask about how to change the recording video type to MPEG format or how to convert mpeg to other formats.
Mpeg converter is born to solve the mpeg related conversion problem. Mpeg converter can convert almost all kind of video formats to MPEG file, such AVI, WMV, ASF, 3GP, MOV, VOB, MPG/MPEG2 and FLV (Flash Video), which could be converted/exported as avi, mpg, mp4 video formats for your later options, while keeping the original video quality. Mpeg converter can also extract audio track from those supported video to m4a, mp3, wav audio formats. besides, it is a powelful video editing tool too.
Mpeg converter lets you trim any splendid clips or episodes of your favorite videos, crop the unwanted black edges of video, apply video effects, and capture pictures from your video.
i am sure this will be a total fresh experience for you, things will be easier if you follow the tutorial below:
step 1. Click here to download, install and then run
Mpeg converter
step 2. Select a format to load video info
To load video info, click Load File button. you can choose one video or more each time at will with the batch conversion capability. define the output path by clicking the output button, you can then name the output file as you like.
step 3. Tune settings for the output video/audio
a. Click the Edit button to edit effect (Brightness, Contrast and Saturation).
b. click Trim button to decide which part of the video you would like to convert using slide bar to specify exact the start time and ending time.
c. For more settings click Setting button to tune the video/audio parameters like frame rate, bit rate, resolution, etc.
step 4 Start conversion
after all the steps above, you are noe set. click start button to feel the fast conversion speed.
I finally was able to do as you said and it worked! Thank you so very much
