Whirlpool LHW0050PQ Front Load Washer Logo
Posted on Sep 06, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Whirlpool WFS1276AW bangs loudly when rinsing and spinning
Anonymous
Level 3:
  • Whirlpool Master 43,501 Answers
  • Posted on Sep 06, 2010
Anonymous
Whirlpool Master
Level 3:
Answers
43501
Questions
0
Helped
10842425
Points
101584
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems Washer noise when spinning
heatman101
1helpful
Drum is loose during Spin and Rinse cycle and banging against side of washer
If it is under warranty, call Whirlpool at 1-866-698-2538. If it is out of warranty, try running the washer with no clothes in it in spin cycle. If it runs fine empty, it may be that when you had clothes in it they were not balanced evenly in the tub. If it runs off balance when empty, then a spring may have broken or come off. Contact an appliance repairman.
Alarm which we do not have before. normal cycle. also on a rinse cycle. ocasionally loud banging noise.
You didn't mention if the machine was giving any error codes. Do the following steps to get any stored error codes and post them back to me.
Select the following on the operator console - DRAIN SPIN, NO SPIN, and then press any button under OPTIONS 4 times (it must be the same button). "C00" will show on the console display as the washer begins diagnostics mode.
4helpful
Loud banging noise during rinse
Most noises from a washing machine occur during the rinse or spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.This will solve your problem.
Washer agitates off balance and makes a loud banging sound until movement stops at the beginning of rinse cycle, advice?
If it makes this noise in the agitate mode and not during the spin cycle, I would suspect that the transmission is going.
4helpful
Spin cycle very loud,
spin surpport defective,,,this part is under warranty,,lifetime warranty..contact whirlpool for replacement of spin basket,,onthejopb
Loud bang during spin
Unplug it and plug it back in after a min. Try to put it threw a rinse spin cycle. Delicate option has a shorter rinse spin time.
See if it suds up, when you hear it trying to drain lift up the drain hose to the wall. It is the gray tube that has the elbow bend, might (should) be hooked to wall. If it isn't moving a good amount of water the machine isn't draining.
Whirlpool clicking banging sound when in spin
most common noise complaint is debris inside pump assy, be removing the lower acess panel you'll find access to the pump through what hey call their button trap, unscrew the port and remove foreign debris,there is always water in that pump so either tip machine back or i put a plastic bag infront of pump prior to opening
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
