Question about Netopia ADSL 2+ MODEM 10/100 EN AND USB FIREWALL SECURITY Router (2241NVGX)
I am trying to get a Nat Type 2 or lower and all i can get in a Nat type 3 on my playstation 3 Is there any trick on this 2247-62 to open ports to get it to work properly besides assigning my stattic IP addr to playstation network under nat applications. Also is there a way to enable UPnP?
SOURCE:
kakee
  • 1269 Answers
SOURCE: Change NAT to open
You need to open all the ports for the xbox live. The NAT of that router model cannot be configured to open. Its just a simple NAT for internet connection.
Posted on Feb 09, 2009
Hardtack
  • 46 Answers
SOURCE: How do i change my NAT connection from moderate to open
This one is simple. Find the IP address that your Xbox is assigned by your router, then put it into the DMZ. This also goes for PS3 users who are having trouble with internet access.
Posted on Feb 10, 2009
SOURCE: Getting PS3 NAT Type 2 with Netopia Router ???
I have nat type 1 with this router but no upnp. access your router. click on advanced setup, click on configure, click on connection, choose ppp over ethernet llc/snap scroll down and click on save and restart connection. call your internet provider and get the username and password for your router. you will need it later. on your ps3, go to network settings, select internet connection settings. the ps3 will ask if you want to continue, select yes.select custom, wired connection, auto detect, PPPoE, enter the username and password you got from your isp, select automatic, automatic, do not use, enable, then press the x button to save, press the x button again to test connection
Posted on May 07, 2009
  • 3 Answers
SOURCE: Getting PS3 NAT type 2 with Netopia router!
u should have dmz on router. but if not u can try your modem. that was my issue. i still use router for connection and stuff but i enables ip/dmz to pass through on my modem and it changed to type 2 more info email me at joshuaboo@aol.com on add me i believe my ps3 thing is ADV_WARfighter
Posted on Sep 24, 2009
Tom Marvolo
  • 708 Answers
SOURCE: change nat from strict to
NAT STRICT
Step 1 : Connect Router - Computer ( Wired )
Step 2 : Open Router setup by typing http://192.168.0.1 on the address bar of the internet explorer
Step 3 : The Default Password is admin
Step 4 : At the top Click Advanced
Step 5 : On the left Click Firewall Settings
Step 6 : Enable DMZ
Step 7 : give the IP Address of the Xbox/PS3/Wii in it
Step 8 : Uncheck the option Enable SPI
Step 9 : Click Save Settings
Step 10 : Test the connection
let me know if this works
Regards
TOM
Posted on Dec 22, 2010
I cant play online becouse of this a NATtype3 what dose this mean
Nat 3 is the result of being hooked into a router without being properly setup for data transfer. essentially it is restrictive.
There are 3 ways to change your Nat type to type 2 or 1. (Nat type 2 meaning that it is properly setup without restrictions behind a router, and Nat 1 being a direct connection to the Internet).
1.) Hook the PS3mag-glass_10x10.gif directly into the modem will result in a Nat type 1, but of course that means disconnecting everything but the ps3 and that's an unnecessary hassle.
2.) Going into the router settings and Port Forwarding the PS3's necessary ports to the Ps3's ip address.
3.) Probably the simplest (on most routers) and most effective is to go into the router and set the PS3's ip address in the DMZ (DeMilitarized Zone), essentially the router doesnt have any say from what comes and goes to the Ps3, which is good so the connection isn't hampered.
Feb 14, 2011 | Sony Playstation 3 (PS3) Console
How do i change NAt type to a lower type
XBOX
You Will Have to Disable the Firewall In Your modem / Router
And IF it is a router then Open The Ports
• TCP 80
• UDP 88
• UDP 3074
• TCP 3074
• UDP 53
• TCP 53
And Also Make sure that UPnP is Enabled
PS3
You will have to open the following ports in your modem /router
Make sure the firewall is disabled in the Modem /Router
Playstation Network Required Ports
TCP 80
TCP 443
TCP 5223
UDP 3478
UDP 3479
UDP 3658
Playstation Online Game Ports
Call of Duty 3:
UDP 3074
TCP 3074
MotorStorm
UDP 3659
UDP 3660
You can use http://whatsmyip.org/ports/ to test if the ports are open.
Jan 06, 2011 | Netopia 2247NWG-VGx Wireless Router...
How do you achieve a nat type 1 or a nat type 2 connection to a playstation3?
PS3
TCP 80
TCP 443
TCP 5223
UDP 3478
UDP 3479
UDP 3658
Call of Duty 3:
UDP 3074
TCP 3074
MotorStorm
UDP 3659
UDP 3660
Jan 04, 2011 | Siemens SpeedStream Modem (4100) (SS4100)
Can I change the Nat type? Can't figure out how to change it from type 3?
XBOX
• TCP 80
• UDP 88
• UDP 3074
• TCP 3074
• UDP 53
• TCP 53
PS3
TCP 80
TCP 443
TCP 5223
UDP 3478
UDP 3479
UDP 3658
Call of Duty 3:
UDP 3074
TCP 3074
MotorStorm
UDP 3659
UDP 3660
Jan 03, 2011 | NetGear WNDR3400 N600 Wireless Dual Band...
I have NAT type 3 (NAT: Strict) on my Playstation 3. I've tried everything, including currently having my PS3 in the DMZ, opening the correct ports & turning off the firewall completely. I can't figure...
i have the same problem, try calling your internet provider they gave me some steps to follow that didn't work but you might luck out and they can help you
Dec 28, 2010 | Video Game Consoles & Games
How do you change from nat type 3 to nat type 2 on this router
To reduce the NAT
1 ) Disable the firewall in the router
2) Enable the Playstation in the DMZ
3) Make sure UPnP is Enabled
Jun 22, 2010 | Siemens SpeedStream 4200 (13A4200001)...
Not connecting to internet
TCP 80
TCP 443
TCP 5223
UDP 3478
UDP 3479
UDP 3658
Call of Duty 3:
UDP 3074
TCP 3074
MotorStorm
UDP 3659
UDP 3660
Jun 19, 2010 | Sony PlayStation® 3 (80GB) Console
I have netgear wirless router but i hardline ps3 but i keep getting nat type 3 i need to know what ports to open on modem to get to nat type 2 can you help
In this regard, I would recommend you to forward certain port no’s on
the Router.
Port numbers:TCP: 80, 443, 5223 and UDP: 3478, 3479.It is in this context, I would suggest you to please try with the
following troubleshooting steps:
A) Assign static IP and DNS address to the XBOX.
1. Assign IP address as: 192.168.1.50; Subnet mask as: 255.255.255.0
and Default Gateway as: 192.168.1.1
2. Assign Primary DNS Address as: 192.168.1.1 and Secondary DNS
Address as: 4.2.2.2
C) Open the ports on the Router using the following steps:
1. Click on Port Forwarding under Advanced.
2. Click on ‘Port Forwarding’ on the left hand column on the screen.
3. On the bottom of the screen, click on ‘Add Custom Service’.
4. Give a name to the service (for example, PS1).
5. Select Service Type as UDP and key in the starting port and ending
port as 88.
6. In the Server IP Address specify 192.168.1.50
7. Hit ‘Apply’.
10. Log Out of the Router Page.
Jan 16, 2009 | Sony Playstation 3 (PS3) Console
My PS3 has no NAT Type!!
there is something known as NAT strict that can happen due to many reasons , NAT or network address translator helps in converting the WAN ip address to LAN side IP address or public to private ipaddress . In a case of NAT strict or no NAT type ur PS3 or the router to which you have connected the PS3 is not able to convert the IP address...
Solution: try logging on to the router manager or PS3 settings and enable the NAT ( it would be in a disabled state or DMZ ( de militarized zone ) state )....
If the nat is already enabled Then try to manually configure NAT by opening the port numbers on the router manager or PS3. Port numbers can of UP or TCP protocol depending upon the games ur tyring to play....
If u donno how u do it then contact sony or the people who gave u the router or ur ISP
Feb 18, 2008 | Sony Playstation 3 (PS3) Console
Netopia ADSL 2+ MODEM 10/100 EN AND USB FIREWALL SECURITY Router (2241NVGX) Logo
56 people viewed this question
Top Netopia Computers & Internet Experts
Prashant M
Prashant M
marty morrison
marty morrison
Are you a Netopia Computer and Internet Expert? Answer questions, earn points and help others
