May be there is some block in the spray pipes...
have you checked them.....
try to clean it once
Start with reading this page
http://ezinearticles.com/?Dishwasher-Secrets---Make-It-Clean-Perfectly&id=20890
other than that it may be that a few parts are failing or not functioning properly start with that guide and if the results dont improve get back to me, for more assistance
Have try to check and clean the unit...?
i would like to ask other info which could help on this problem..
thank you
Things You’ll Need:
Bleach
Vinegar
Orange Tang Drink Mix
Baking soda
1. Check the temperature preset before cleaning your dishwater. This is the temperature of the water used for washing. Some dishwashers require water to be 120 degrees or higher, while others require 140 degrees or higher. Check your dishwasher’s make & model mentioned in the user’s manual. Learn if your dishwasher has a pre-heating mechanism for water when it is too cold. Use a thermometer to measure the temperature just before the washing cycle begins.
2. Identify and locate the type of cleaning required in your dishwasher. Scale, rust, mold, discoloration and food stains are some of the most common concerns that require regular cleaning. Follow the steps below to clean each of these
3. Add one tbsp of bleach after emptying the contents of dishwasher. Run a full cycle. This will clean any mold built up in the dishwasher and leave the dishwasher sparkling and glowing.
4. Try cleaning discoloration and scale off your dishwasher by adding one half container of Orange Tang Drink Mix. The citric acid present in the mixture helps to loosen up the hard water deposits as it removes and cleans the scale from your dishwasher. Run a regular cycle.
5. Place a coffee cup filled with vinegar in the dishwashing rack and run a full cycle of dishwashing. This will clean your entire dishwasher. This is one of the easiest techniques and works well as preventive care. If vinegar is unavailable you can also use baking soda.
