Kenmore 63942 Dryer Logo
Posted on May 12, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Kenmore Dryer - Ignitor will not fire
I have replaced the ignitor and the radiant sensor. The ignitor still does not heat up.
Model # is 110.72612100
john gagnon
Level 3:
  • Master 943 Answers
  • Posted on Sep 11, 2008
john gagnon
Master
Level 3:
Answers
943
Questions
Helped
324249
Points
2163
Thanks for the question The problem is with a thermal fuse located at the back remove back panel the thermal fuse is located on the air vent 2 small wires go to it replace it . And check the venting make sure the vent is clean because this termal fuse will break down because of poor venting Thanks for the question The appliance doc
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jul 22, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1184
Points
MY Kenomore 90 series dryer turens and tumbles but no heat. What can it be?
1helpful
Kenmore Gas Dryer Model # 97591240 75912 The dryer will not heat-up. ... I think the pilot light is out because I'm not seeing any fire in that little peephole at the ...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
1helpful
I have a kenmore gas dryer, the drum turns but no heat, I replaced the radiant sensor and the control thermostat but still no heat?
here is a partial list of componets that could cause the dryer to not heat
Ignitor
control t-stat
high limit t-stat
gas valve coils
thermal cutoff
thermal fuse
flame sensor
electronic control/or timer depending on your exact model
cycling t-stat
motor
Jul 23, 2011 • Dryers
I have a 7yo Kenmore Elite gas dryer w/no heat. I tested all the possible culprits with my ohmmeter. I found the ignitor was not glowing so I replaced it. Now it glows but I still have no heat
The glowing if the ignitor indicates that the circuitry is good but the flame/radiant sensor is bad and/or one or both of the gas valve solenoid coils are not working. The flame/radiant sensor bypasses one the solenoid coils then when power is applied to the ignition circuit, the first coil opens the first valve, the ignitor glows and the flame/radiant sensor gets heated. It's contacts then opens when heated enough to unbypass the second coil and allow the gas to flow and be ignited.
Make sure the flame/radiant sensor is properly in place and aligned with the ignitor to allow proper heat sensing. You may check the continuity between the sensor's contact terminals as the ignitor glows. At first, the terminals should read close (zero resistance) and then open (infinite resistance) after about 30 seconds or so. If this is not the case, the sensor is not working and must be replaced.
The solenoid coils, one with 2 prongs and the other has 3, sitting on top of the gas valves must be both replaced if the flame/radiant sensor turns out good. But before doing so, make sure to run a test with the dryer completely assembled because sometimes the gas do not ignite when the dryer's cabinet is open. This is to prevent unnecessary replacement of the coils.
Feel free to update us about the result and if you need further advice.
Dear Sir/Madam: I was reading some instruction online on how to troubleshoot a gas dryer and I got confused on two items about the flame/radiant sensor operations. One described it as light sensor and it...
If your dryer is not lighting you should first ck to see if the ignitor is glowing if it is there is a heat sensor looks like a big wire 1/8th inch around that is near the ignitor that senses the heat and then the gas valve kicks on. There should be an access plate to see the glowing ignitor with it all hooked up. If you are set on cking it without hooking it up to the gas put your hand on the gas valve and when the ignitor heats up and the sensor tells the gas valve to turn on you will feel a click. The normal problem is a bad ignitor. If its the glow type its obviouse if its the sparking type you will hear it popping if its working. I believe yours is a glow type. good luck
Aug 16, 2010 • Dryers
My kenmore model 11070812990 gas dryer won't heat. I have removed it to the garage so I can work on it. I have the front, back, and top off, Have determined the ignitor is working, what should I be looking...
HOW DID YOU DETERMINED THE IGNITOR WORKS? DID IT GLOWS REALLY RED? IF IT DID, MEANS YOU HAVE GOOD FUSE AND YOU SHOULD CHECK THE RADIANT SENSOR(NEXT TO IGNITOR) AND THE COILS.IF THE IGNITOR DID NOT GLOW AT ALL, THEN YOU HAVE A BROKEN FUSE. IT IS LOCATED IN THE BACK. ABOUT AN INCH LONG AND IT'S NARROW. CHECK FOR CONTINUITY. OPEN MEANS IT'S BAD. OHM READING MEANS GOOD.
[email protected] OR 714-334-1998. I CAN WALK YOU THROUGH PROCESS
Kenmore model 110.72702101. The dryer ignites when you first turn it on. When the gas shuts off it does not relight when the ignitor glows. I replaced the ignitor and the radiant sensor and still have the...
if you have already replaced the ignitor and the new one is glowing white hot, not orange, and you have replaced the sensor, then the next logical part to replace would be the gas coils. hope this will help solve the problem.
1helpful
Flame does not cycle on Gas Dryer
This problem is caused by faulty gas valve coils. These electrical coils are right above the gas valves and when energized, these solenoids open the gas valves. It is recommended that if any of the gas valve coils are suspected of fault, that they both (all) be changed at once. Hope this helped and best wishes.
3helpful
I have a AMANA gas dryer model LGA80AW and it is not heating. I took the front panel off cleaned the lint from within the cabinet and exhaust pipe. What I've noticed is that the starter comes on and lights...
When you say "starter" I assume you are talking about the "ignitor" and it is glowing.If the ignitor stays glowing continuously then the radiant heat sensor, normally closed, is not opening OR if the ignitor lights up than turns off after about 10 seconds but no flame, then the coils (doesn't matter which one of the two) are bad. The coils are located on top of the gas valve and the radiant sensor is located on the side of the burner chute....Good Luck
The Squirrel
4helpful
Kenmore gas dryer not heating
GAS DRYER, NO HEAT. CHECK THE HEAT SETTING FIRST.
IS IT ON AIR FLUFF? I'M NOT BEING SMART, BUT YOU WOULD BE SURPRISED HOW MANY CALLS I TAKE THAT ARE ON AIR FLUFF. SECOND, LISTEN FOR A DISTINCT CLICK WHEN YOU TURN ON THE DRYER. IF YOU HEAR IT, LOOK IN THE INSPECTION HOLE ON THE FRONT OF THE DRYER, OR REMOVE THE TOE PLATE TO VIEW THE IGNITOR. IF THE IGNITOR GLOWS AND THEN CLICKS OFF BUT NO FLAME, YOU HAVE A BAD SOLENOID ON THE GAS VALVE. IF THE IGNITOR GLOWS, BUT NEVER CLICKS OFF, THE RADIANT SENSOR ATTACHED TO THE SIDE OF THE BURNER ASSEMBLY IS BAD.
IF YOU DON'T HEAR A DISTINCT CLICK WHEN YOU TURN ON THE DRYER, THE MOST LIKELY CAUSE IS THE THERMAL FUSE LOCATED ON THE BACK OF THE DRYER DOWN NEAR THE EXHAUST DUCT. IT IS A SMALL WHITE ITEM ATTACHED TO THE EXHAUST DUCT WITH TWO WIRES ATTACHED.
Apr 10, 2008 • Dryers
1helpful
Kenmore elite gas dry 6 years old - no heat
PUT YOUR DRYER ON AIR FLUFF AND TURN IT ON. THEN SELECT A HEAT SETTING. IF YOU HEAR A DISTINCTIVE CLICK WHEN YOU SELECT HEAT, THEN CHECK FOR A GLOWING IGNITOR. MOST KENMORE/WHIRLPOOL DRYERS HAVE A PEEP HOLE IN THE FRONT LEFT SIDE OF THE DRYER. REMOVE A PLASTIC COVER TO VIEW INSIDE.
IF THE IGNITOR GLOWS, AND THEN CLICKS OFF, YOU HAVE A BAD SOLENOID (COIL SETTING ON TOP OF THE VALVE). IF IT NEVER CLICKS OFF, YOU HAVE A BAD RADIANT SENSOR( LOCATED ON THE SIDE OF THE BURNER HOUSING). IF NO IGNITOR GLOWING, THE IGNITOR IS BAD.
IF WHEN YOU SELECT HEAT, THERE ISN'T ANY CLICK, THEN THE THERMAL FUSE LOCATED BEHIND THE BACK PANEL DOWN NEAR THE EXHAUST IS BAD. IT IS A SMALL WHITE ITEM WITH TWO THIN WIRES ATTACHED TO IT.
Apr 07, 2008 • Dryers
Top Kenmore Dryers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
