Kenmore 75503 Stainless Steel Dual Fuel (Electric and Gas) Kitchen Range Logo
Posted on Sep 05, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Oven temperature in main oven does not reach above 200 degrees. Is this a coil problem or a themostat problem?
Anonymous
Level 3:
  • Kenmore Master 43,501 Answers
  • Posted on Sep 07, 2010
Anonymous
Kenmore Master
Level 3:
Answers
43501
Questions
0
Helped
10837796
Points
101584
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
I have a Kenmore 362 75191893 gas range. The oven begins to heat, but doesn't even reach 200 degrees. It seems like it has been reaching lower and lower temperatures over time. Besides this new problem,...
If the burner does not light (with a huge flame above it) I would direct you to some gas line blockage.
But if the burner flame lights good and then goes out early before it's good and hot then I would direct you to a defective oven temperature sensor. The sensor is in the upper wall of the oven cavity, can be bought at your local appliance parts store, and installed by any handyman.
Dec 05, 2010 • Ovens
Oven heats to 200 and indicator dings
Try to set it at 500 degrees and see if it goes off at 350. If it does, then it probably needs calibrating. You can calibrate it by taking the knob off and finding a set screw in the stem where the knob sits. If this is not the problem, you may have to replace the thermostat. By the way, check to see if your temperature probe is not touching the wall of the oven. It will give it a false reading. Let me know if any of these things work and we will go from there.
Oven only reaches temp of 220 degrees.
meter the electric-220 metering the positives...110 metering 1 positive & ground at a time...Ohm the element if shows open(10 dollar multimeter doesn't move) then is bad.Can be reached from the back just above where the power attaches,for safety disconect the power
2answers
Oven taking a long timt to heat to temperature
Try shutting off the breaker for about 10 minutes - then bring the power back on
Oven does not maintain temperature. Part 2
sometimes when they get hot that is when they fail
Top Kenmore Kitchen Ranges Experts
Paul Carew
ZJ Limited
ZJ Limited
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
